Question about Oracle Database Enterprise Named User Plus
Calculate number of months in date range
I am trying to write a formula to calculate number of months in a date range any ideas?
Conficio
  • 9 Answers
SOURCE: Creating a holiday accrual spreadsheet.
Hi, I guess you mean vacation accrual. It's hard to help you here, without knowing the exact accrual formula. However here are some tips: Set up a column with the start date for each employee and use the today() function to get today's date. You can use the days360() funtion to calculate the number of days between two dates, assuming regular 30 days/month. For more date related functions, click on the Fx (letter f with an subscript x) to the left of the value/formula entry field at the top of the spreadsheet. Thsi gives you a wizard with a list of functions. Select the Data/Time group and you see all available functions and can interactively pull them together. Good luck K
Posted on Sep 06, 2007
CNewton2
  • 27 Answers
SOURCE: EXCEL DATE RANGE FORMULA
Assuming birthdate is in cell B2:
=IF(B2<DATE(1997,5,1),"Too Young",IF(B2>DATE(1998,4,30),"Too Old","OK"))
Posted on Oct 27, 2007
  • 40 Answers
SOURCE: Problem with formulas
You may want to try =COUNT(A1:C9) for example. In brackets type the range of cells you want to count and excel will give you the number of cells that contain numbers.
Posted on Aug 19, 2008
  • 35 Answers
SOURCE: Need excel solution
As stated, the forumla solution in is
= (Due Date - Create Date) x 24
However, the key is that the result cell (where the formula is) should be formatted using the 'general' format, not date/time. So, I think in this example, the result should be 730.65 hours
Posted on Feb 19, 2009
RickOz
  • 145 Answers
SOURCE: How to calculate the difference of two dates by
To calculate the difference in Years use =Year(c,r)-Year(c,r)
To calculate the difference in Months use =Month(c,r)-Month(c,r)
To calculate the difference in Months use =(c,r)-(c,r)
c= column, r= row
You will need to format the source cells as dates
Posted on Mar 15, 2009
How can I calculate the EMI of a home loan of 90 lacs?
Banks and Non-Banking Financial Companies use the following formula to calculate EMI of a home loan. This is the formula for calculating compound interest. Applying the same formula for a home loan of Rs 90Lakhs, we get,
EMI = [P x R x (1+R)^N]/[(1+R)^N-1]
Where,
P= Amount borrowed- Here, it will be 90 lakhs
R= Rate of interest per month
N= Number of months in the home loan tenure
Going by the current lending rates followed by the financial institutions, we will consider R to be 9% per annum (to be converted to % per month) and for the loan tenure, we will take 20 years/240 months.
Substituting all values in the above formula, the home loan EMI comes out to be Rs 80,975 per month.
You can easily calculate the EMI for your home loan for any bank or NBFC using a free online Home Loan EMI calculator. You can also find this handy tool on the online portals of most banks and NBFCs. All you have to do is feed in the values in the respective fields and receive the answers.
Oct 09, 2017 | The Office Equipment & Supplies
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
I need to add a year to dates on excel spread sheet there are more than 440 diffrent dates....Please help?
I assume that the dates you want adjust are in date form and are in regular columns (or rows).
If so, then you can use a formula like this =DATE(YEAR(A3)+1,MONTH(A3),DAY(A3))
where the original date is in cell A3.
You can then copy this formula to calculate all the new dates you need, and then copy the results back over the original dates as VALUES.
Oct 17, 2013 | 1996 Italdesign Formula
Calculate Quarters between any two dates
not sure if this is what you are after entirely but should at least help you out some what
=DATEDIF(A3,C3,"m")/3
As you said you cant just divide by 3 but I have divided the formula by 3 to see how many 3 months will go into the output you could maybe have another formula to divide it by 2 to see if it will divide by 2 to see if you get a whole number or not, if you do then you can just return the first part before the dot ( using split function ) and if the value is less then 1 then obviously the 3 months has not passed between the 2 dates
May 09, 2009 | Microsoft Office Excel 2003 for PC
How to calculate the difference of two dates by year, month and day using the formula in excel?
c= column, r= row
Mar 15, 2009 | Microsoft Office Excel 2003 for PC
Calculation of end date in format dd/mm/yy
Assuming you put the start date in cell A1, put this formula:
=DATE(YEAR(A1),MONTH(A1)+15,DAY(A1))
in the cell where the result wanted to be appeared.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | Microsoft Office Excel 2003 for PC
Converting date of a month to last working day of the month
use the below formula to get the date of the LWD (Monday thru Friday) of the month.
Assumed that if the date in cell A1 is 6-May-2005. then formula will be
=DATE(YEAR(A1),MONTH(A1)+1,0)-(MAX(0,WEEKDAY(DATE(YEAR(A1),MONTH(A1)+1,0),2)-5))
Jan 30, 2009 | Microsoft Excel for PC
Formula for calculating the days beween months
for example, cell A1 has date (01-01-2008) and cell A2 has current date (08-24-2008) and cell A3 shows total days, is that you want to know? if yes, apply formula as under...
cell A3......(properties set as General to show digits)................ =SUM(A2-A1)
Aug 25, 2008 | Microsoft Office Professional 2007:...
Aug 19, 2008 | Computers & Internet
Sep 05, 2007 | Microsoft Office Standard for PC
Oracle Database Enterprise Named User Plus Logo
112 people viewed this question
Top Oracle Computers & Internet Experts
CNewton2
CNewton2
Level 1 Expert
cwradio73
Bonded Repair
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
