Question about Seth Thomas Home
Removed the chime's from my Seth Thomas mantel clock to clean put back in wrong because they are way out of chime can you tell me how to put back in the right way
  • 320 Answers
SOURCE: I have a 34 year
You got it, the problem is the gears within the chimes. Apply a singer oil lubricant or any other lubricant can help fix the problem.
Posted on Jul 14, 2011
reyjoshua07
  • 1157 Answers
SOURCE: i need to know how
Hi ajhazel1,
Please follow the steps below on how to set the alarm on your seth thomas mantel pendulum clock.
1. Determine if your Seth Thomas mantel clock is a 7-day clock or an 8-day clock. On most models it will say right on the face of the clock which type it is. Seven-day clocks must be wound every 7 days, and 8-day clocks must be wound every 8 days. If you are unsure you should wind your clock every seven days.
2. Look on the back of the clock. You will see three large holes (just large enough for the clock winding key to fit into) plus one or two smaller holes (often just large enough for the small end of the key to fit into). The two smaller holes are for speeding up or slowing down the clock and for turning the chimes off and on. The three larger holes are the ones we are interested in--they are the ones we will need to wind every 7 or 8 days. On some models the three winding holes are on the front of the clock. Winding instructions are the same, regardless of where the winding holes are located.
3. Push the large end of your clock winding key gently into the hole on the right as you look at the back of the clock. This hole allows you to wind the 15-minute chimes. Gently turn the key clockwise. Keep turning it until you feel resistance and the key stops turning. Remove the key.
4. Insert the large end of your key gently into the center hole. This hole allow you to wind the main clock mechanism, which allows the clock to run and to keep time. Turn the key clockwise firmly but gently until you feel resistance. When the key no longer wants to turn simply remove it.
5. Insert the large end of the key into the hole on the left. This winds the hour chimes. Turn the key clockwise firmly but gently until you meet with resistance. When the key no longer turns easily remove it and place your clock back on your mantel. Your clock is now set to run for 7 or 8 days, depending on the model you own.
6. Use your hand to start the pendulum swinging once the Seth Thomas mantel clock has been set to the right time. The pendulum should be located in the back of the clock. The clock will not keep time if the pendulum is not moving.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 24, 2011
SOURCE: i have my mother's seth thomas mantle clock
If your clock has a small hole between 4 and 5 then you can turn off the quarter hours chimes using the small part of the key. If your clock does not have that small hole you can not turn off the quarte hor chimes.
Posted on Jan 31, 2013
AndrexT
  • 19031 Answers
SOURCE: I have a Seth Thomas Westminster chime clock. It's 2 minutes ahead. Can I turn the minute hand backwards safely? If not, then how do I handle this?
Yes, the clock part is electric.
Posted on Jan 07, 2017
AndrexT
  • 19031 Answers
SOURCE: have a Seth Thomas G/D clock the left cylinder is all the way up never moves. Does that operate the hour chimes?
have you turned the chimes off? One generally does time, the other does chimes.
Posted on Feb 05, 2017
Seth thomas manual for models E658-E659and E662-E663 series floor clocks
Try Googling (seth Thomas)(*)(manual) without parens.
* E658, E659, E662, E663. Search models one by one.
Nov 15, 2017 | Seth Thomas Home
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register ยท My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
How to set chimes on seth thomas mantle clock
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Aug 31, 2014 | Home
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    I have a Seth Thomas Grandfather clock with three different chimes and chimes at every 15 minutes. The problem is it is chiming 2 hours shorter than the actual time. Example say it is 11:00, it is...
    Thanks for contacting FixYa.
    I wish I had an aswer for you but I dont. Here is a link for a repair man that has an 800 # toll free to call for estimate.
    http://clock-repair.net/site-map/seth-thomas-clock-repair/
    Best regards. Jewel
    Sep 13, 2010 | Watches
    Home Logo
    41 people viewed this question
    Top Seth Thomas Home Experts
    Austin
    Tom Chichester
    UsedClockPartsdotCom...
    Are you a Seth Thomas Home Expert? Answer questions, earn points and help others
