Question about Kenmore Washing Machines
Removing the inner plate with timer from the front plate on a Kenmore washer model 110.92587210
I am trying to remove the timer, as the face plate is bent up.
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: model 80 Sears Kenmore washine(Remove inner basket)
under the agitator youll see a lock nut appox 2-3in, around "locking" the inner basket to the outer basket. although they do sell a spanner wrench to remove this nut, A decent pipewrench and little muscle will get it loose, after that the tub will pull right out. assuming youve taken off the outer tub gasket cover
Posted on Mar 10, 2008
  • 1073 Answers
SOURCE: kenmore dryer how to remove kick plate
if this is a 4-6 year old dryer then the kick plate is held in place with 2 spring clips one on each side a putty knife will disengage the clips,, tip once you get one of the sides loose, put a wedge of paper into the crack on the side and move to the other side to work on the ohter clip
Posted on Apr 11, 2008
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Posted on Jan 15, 2009
  • 7 Answers
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Posted on Jan 30, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
How to change the timer on a kenmore 40042
By removing back plate of washer you should see the wiring to the timer and also the timer it self. By removing the button on the front of the timer you will see two screws which remove the timer.
Feb 11, 2011 | Kenmore Washing Machines
Kenmore Calypso washer, has debrise and clothing
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support. Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate. Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate.
6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it. The inner wash plate is keyed and should only install one way.
7. Insert the main wash plate and insert mounting bolts. Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly.
8. Reinstall the center dome on the wash plate by snapping it back in place.
9. Reinstall, the balance ring on the wash tub.
The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled:
Wash Plate Dome
Main (Outer) Wash Plate
Inner Wash Plate
Leveler Assembly
Inner Wash Plate Seal
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water will not drain, drumb won't spin
check water pump for faults and or blockage it will not spin as there is to much water inside once it has drained it should spin this is a safety feature
Jan 15, 2010 | Kenmore HE2 Plus Front Load Washer
How to remove outer washplate from. kenmore
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Jul 24, 2009 | Kenmore Washing Machines
My kenmore elite with calypso motion top load is leaving black marks on my clothes and they are getting caught between to bottom plate and the side wall, the plate is fairly new.
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Jul 08, 2009 | Kenmore Elite 45986 Front Load Washer
Agitates but does not spin Kenmore 5 year old Model 110
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Apr 03, 2009 | Kenmore Washing Machines
Removing face panel on Kenmore clothes washer 417.40412700
Mar 09, 2009 | Kenmore Washing Machines
Front door plastic face plate of washer HE3t
yes. there aretorque screws around the inside frame remoive them and the 2 pieces will seperate. you can replace it then. be carefull if you remove the screws from the hinge the whole door will fall off. only six or so screws need to be removed
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
27 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
