Question about Lifespan Exercise & Fitness
E6 error code on LifeSpan Fitness R3 Recumbent Bike...pls help...tnx!!!
5 Suggested Answers
SOURCE: error message on recumbent bike
The problem might be the gearbox. I know because I have the same problem.  Keys fitness is out of business, but "The Treadmill Doctor" has purchased the inventory of parts for the bikes. They will help you troubleshoot, and have parts available if you need them. The number is 1-888-340-0482. Or, you can go to treadmilldoctor.com.
Posted on Apr 03, 2009
SOURCE: Life fitness recumbent bike problem
Hi
We had exactly the same thing. If you take the covers off you will find a black battery pack in the bottom. It is about the same size as a cordless drill battery. We got a replacement from Maplins - cost about £10. It works perfectly now.
Posted on Jun 17, 2009
maxtreadmill
  • 832 Answers
SOURCE: Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Posted on Apr 17, 2010
maxtreadmill
  • 832 Answers
SOURCE: Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
Posted on Jun 01, 2010
SOURCE: i need the power cord for a vital fitness exercise bike RB260.
If you need service or parts for the vital fitness RB260 bike call 888/337-2883 mon-fri 8 am-4:30pm (EST)
Posted on Nov 28, 2010
Need socket size, 6v battery type and manual for Vital Fitness RB260 recumbent bike. Bought used, and socket for adapter fell out between seller and home. :(
Battery is for the display only.
try these people for the battery
http://www.fitnessrepairparts.com/cart/ViewItem/3027589
AC / DC Adapter For VITAL Fitness MB350 RB260 Exercise Bike ...
https://www.amazon.ca/Adapter-Fitness-Exercise-Supply-Charger/.../B00MPGU70KAC / DC Adapter For VITAL Fitness MB350 RB260 Exercise Bike Power Supply Cord Cable Wall Charger Mains PSU: Amazon.ca: Electronics.
Search for Vital Fitness rb260 ' Fitness and Exercise Equipment ...
www.fitnessrepairparts.com/part_search/CatalogSearch/Vital%20Fitness%20rb260Find Vital Fitness rb260 for exercise and fitness equipment. Use our diagrams and parts lists to locate the right part for your treadmill, elliptical, or strength ...
this is the closest I can find to a manual. Probably all made in the same Chinese factory.
http://lifecorefitness.com/template/images/user_manuals/1050RBs_Recumbent_Bike_Owners_Manual.pdf
vital fitness rb 260 Google Search
Jan 17, 2017 | Exercise & Fitness
E6 error code on lifespan tr200 treadmill
please proceed according and fix it. God bless you
trouble +cause+ solution
E6 Faulty Safety key Check Safety key or switch
Elv. Motor not moving Check Elv. Motor
connections
Elv. Motor screw binding Clean screw, lubricate or
remove obstruction
Elv. Motor out of range Check motor zero position
Elv. Potentiometer Calibrate elevat ion motor
Jan 20, 2013 | LifeSpan Fitness TR200 FoldNStor Compact...
Apr 17, 2010 | Life Fitness 9500RHRT Recumbent Bike
Hi
Jun 16, 2009 | Life Fitness 9500RHRT Recumbent Bike
Error message on recumbent bike
Jan 07, 2009 | Ironman 430r Recumbent Bike
Vital Fitness RB-251 Recumbent Bike Manual
Can I purchase a computer for my RB330P recumbent bike? If so where and how much?
Aug 23, 2008 | Sport & Outdoor - Others
Exercise & Fitness Logo
Top Lifespan Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
tel66421938
tel66421938
Level 1 Expert
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
