Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
ICE machine won't turn off!!
My aunts approx. 14 year old Amana 25 freezer is driving us nuts! It's been out of comission for quite a while and something got knocked back on. The darn thing turns and grinds and make the most awful noises continuosly throughout the night and day. How do we shut it off for good. She doesn't EVER use it. Please help.
  • SpinneRminD Nov 25, 2007
    THANKS WE WILL TRY THAT. I THINK YOUR TALKING ABOUT THE ONE UNDER THE TRAY TO THE RIGHT? HOPEFULLY I DONT JUST BRAKE THINGS. HAHA
    SaraH
  • Anonymous Dec 30, 2008
    I have the same problem but I don't know how to put the metal piece back in the ice maker to stop the water. Is there a picture somewhere of what this should look like? This is a 12 year old Amana
  • 290 Answers
To turn off the icemaker, raise the metal arm all the way to the top so that it stays in the off position. You can remove it completely by taking out the screws that hold it to the cabinet and unplugging the wiring connector.
Post back if you have any questions.
Posted on Nov 21, 2007
  • Michael  Lindley
    Michael Lindley Nov 22, 2007
    Just wanting to follow up on your icemaker and see if you got it unhooked.
    Thanks/Mike
I have a Samsung refrigerator with a bottom freezer. The 'fridge and freezer temp settings are displayed on a panel between the upper and lower doors. The unit is about 4 years old. About a year ago,...
Hi adc3,
If the display has stopped working, it is often caused by a blown fuse. Please locate the main control board and check if there's a fuse that may have blown. For the ice maker issue, please check if the ice maker has been turned off. You can check it by looking for a wire that looks like a coat hanger that is located at the right side of the ice maker. Ensure that this wire is not in the raised position. If it is turned off, just simply lower the wire to the down position to turn on the ice maker. If this did not work, please check the tooth on the drive or driven gear of the ice maker. If you noticed a broken tooth you should replace the ice maker.
Hope it helps.
Thank you for using FixYa.
Jun 14, 2011 | Samsung RF265AA Bottom Freezer French Door...
I have an amana arb2557csl top fridge that quit working today. yestarday was fine today hot. no noises that i am aware of. it is around 5 and 1/2 years old. can i fix it without paying a fortune? what...
you have a good brand . back to problem ck for ice on back wall of freezer if so you have a defrost problem and coil is blocked with ice . if no ice make sure the fan inside and down under neath are working and clean the coil. all of these will prevent the unit from cooling .. hope this helped mm
Jul 03, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
My Amana refrigerator defrost timer is supposed to cycle every eight hours. Instead it takes about 14 hours to cycle around back to the defrost mode. The defrost mode does last for the proper 20 minutes....
Relax, some people exagerate was all I was saying.
Anyhow, go to a good parts store and ask for a Supco EDT (Electronic Defrost Timer) replacement as they are more reliable and not much difference in price.
May 15, 2010 | Amana ABB1921DE Bottom Freezer...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Ice Maker quit, everything started to thaw out.
Good day,
Limited information. The ice maker will go into auto lockout if the freezer goes above 14 degrees.
Motors make noise.
There is a fan motor behind the back wall, of the freezer compartment. If the machine is turned on, it should run, and you should be able to hear it.
If not, remove the rear panel and inspect.
The second fan motor, is located in the back rear of the machine, behind the rear cover, it should be running as well.
If both are running O.K. then it is in the compressor itself.
A pricey problem, if it's the compressor. Should be checked by a qualified tech.
P.S. If you feel it is a compressor problem, and the unit is less than 5 years of age, then contact your selling dealer. It would be under warranty.
Jan 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
I have an amana 20 about 25 yrs old starts warming in the freezer
sounds like the little fan behind the ice maker is getting stuck replace it before its too late
i found my parts at repair clinic.com
Jul 03, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Compressor not starting
the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
78 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
