Question about Mitsubishi VS-70709 TV
My VS-70709 willclick when the power button is pushed, but will imeditaly turn right back off. Any ideas?
  • 7 more comments
  • mikey2274 Jul 23, 2009
    Where can I order the ballast? What should I expect to pay?
    Hmmm...I tried calling Mitsubishi and the guy I spoke with did not see that part listed for my model and said that he wouldn't be able to sell me one unless I had an account set up with them.
    Just one click. Well...one when I turn it on and one immeditely afterwards. Is it going to cost me to set up an account? The guy said that the word "ballast" was not even listed as a part for that tv. I messaged a guy on ebay about a ballast that he had listed for Mitsubishi tv's, but I am not sure if it is for my model. I asked him if he had one that would fit.
    No, I do not have a service manual. Do you have a link or know where I could find one? Between my dad and I, we have plenty of electronics experience and feel confident that we could find the source of the problem.
  • 6,784 Answers
HI, you have a weak ballast. this is the power regulator for the lamp in your set. replacing the ballast will fix this issue.
Posted on Jul 23, 2009
  • 3 more comments
  • Michael Masters
    Michael Masters Jul 23, 2009
    Ok, due to the fact that the aftermarket sales of this particular ballast has been discontinued, you will need to contact Mitsubishi directly for this replacement part. you will need to give your unit model number to the Representative and, they will special order this for you.
    Unfortunately, it has been discontinued.
    Normal retail sale price for this part will be $78.00
  • Michael Masters
    I see. i have it listed under your model but, its no longer available on the aftermarket. shows to be discontinued. special order recommended. all projections unit will have a ballast device to power the lamp. How many clicks are you actually hearing?
    They will normally ask for you to register.
  • Michael Masters
    Ok, i need to change the dynamics of my solution. your set is running a optical assembly that uses CRT lamps and not filament based ones. this will change everything here. your set doesn't have a conventional ballast. the power for the bulbs are fed directly from the power board or , deflection assembly. there is a HV block and, flyback transformer that is damaged on this assembly that will need to be replaced.
    I recommend preforming a diagnostic test at this point. there may be many issues here and, a diagnostics test is need at this time. Do you own the service manual for this set?
  • Michael Masters
    The PCB Main is basally where the issues are isolated.
  • Michael Masters
    Here is a link to the Actual service manual with the error code procedure and all part numbers needed.
    CLICK
Reset passcode for vs60609 Mitsubishi tv
check the english service manual
http://www.manualsdir.com/manuals/118985/mitsubishi-electronics-vs-60609-vs-70709-vs-60719-vs-45609-vs-55609-vs-50609.html?hl=ru
Mar 16, 2015 | Mitsubishi Televison & Video
Mitsubishi VS-70707 rear projection TV
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Jan 31, 2008 | Mitsubishi WS-55807 TV
Tv turns on for 20 secondsthen shuts off
There is short circuited component/s at its circuit board. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 02, 2013 | Mitsubishi VS-70709 TV
I NEED TO MOVE MY MITSUBISH VS 70709 UPSTAIRS AND I NEED TO KNOW HOW TO TAKE THE BASE OFF FROM THE SCREEN
This may be one of the models that comes apart--if it is on either side you will see two plastic caps--beneath are either regular bolts or L shaped ones you turn.
Most of the sets that had the feature needed the front screen removed first to do this.
If you do not see the black plastic caps (two on either side) it does not have that feature.
SD TECH
Sep 28, 2010 | Mitsubishi VS-70709 TV
Mitsubishi vs-60803 turns relay on board then goes
replace the power relay the contacts are burned and, will not latch.
Jul 22, 2010 | Mitsubishi VS-60803 60" Rear Projection...
Something buning back of tv red lines going off
Ur tv have convergence problems,it dead.Ur 2 STK convergence ICS are defective,and all or some of it supporting resistors.The shop will cost u $300-350 for parts and labors.
May 08, 2010 | Mitsubishi VS-70709 TV
I have a VS 70709 not getting any picture
Code 2_3 is Horizontal Deflection Problem
Jul 01, 2009 | Mitsubishi Televison & Video
VS-45607 Rear Projection Television
Resoldered connector DY on the yokes and check caps C411, 2200uf/35v and C412, 10uf/50v on main pc board.
Bill
May 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-70709 TV Logo
209 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
