Question about Cell Phones
Anoying clicking noise When in idle mode
Just recieved my SCI Phone. When it goes into idle mode it makes intermittant clicking noise (a bit like a camera click) I think it is when the idle wallpaper changes itself. Can not find a way to disable the noise or Idle wallpaper also tried to disable g sensor /sport sensor and tried a factory reset plus removing battery while still powered on. Any ideals?
Makes high pitch whistle
indicates wind turbulence noise
possible around rear view mirrors , weather shields , door edge , bonnet edge , headlights
trial and error is to place tape over adjoining edges to see where a placed tape stops the noise
Nov 27, 2017 | 1999 Jeep Grand Cherokee
Clicking noise idling
check whether is your belt,as it is old one ( if it is ) and when is cold is giving the clicking noise but when it become hot it stops. Good to try is if you do have a silicone spray do spray on the belt when you do have the noise and if is the belt surely you will notice the difference.
Good luck
Mar 10, 2014 | 1995 Buick Riviera
Clicking noise at idle on a 2001 crysler 2.7 v6
Try to adjust all valve clearance to specs...
Sep 10, 2012 | Cars & Trucks
Can i put an at&t sim card into my sci phone?
hello,
The answer to your question is no.! while because your sci phone is a virgin phone i.e there are not compatible, what you are to do to make your sci phone to be compatible with your at&t Sim you will have to unlock your sci phone with a computer software.
Please if you can not carry out this problem out on your own with the computer software
then you will have to take the phone down to the at&t customer store to give you an helping hand this service is free.
Hope this help?
thank you and thanks for using fixya.
Nov 19, 2010 | AT&T Cell Phones
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
1998 Honda CR-V makes low pitched shuddering or growling noise intermittently when turning sharp right or left at very low speeds.
YOU should find that if you let off the turn a bit and not turn on hard full lock,, now do this stopped and someone sitting in the drivers seat and bonnet open and turning the steering wheel with engine running in idle
if the noise goes and the shuddering goes then its the powered steering pump is either low in fluid or airrating or if belt driven then see if belt is trying to stop on full lock and if it is then try a new belt or other wise its the pump faulty.
Oct 14, 2009 | Honda CR-V Cars & Trucks
My laars swimming pool pilot light keeps going out and it makes a clicking noise when it fires up and the pilot light goes out? it has been going on and off alot recently but can work for weeks on end then...
check power pile conections on gas control valve.it is the 2 wires that come from pilot asembly.if they are loose or have rust or oxidation this can affect pilot and cause intermittent outage. let me know
Jul 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
No Sound
you need to replaced the speaker on the phone
Jun 17, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Phone calls get cut off and fax goes into recieve mode
If you are using the fax as both for calls and receiving faxes make sure you have the fax set up to FAX/TEL mode. This should solve your problem.
May 22, 2008 | Canon FAXPHONE L80 Laser
Cell Phones Logo
83 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
