Question about GE Spectra JGBP35 Gas Kitchen Range
F2 Error when using the oven GE XL44 Gas Range
It used to happen anytime I use the Set Time or Cook Time function, but now it happens when the oven is being used for an extended cook time or 30+ minutes.
Is this something we can fix ourselves or do we need a technician. My husband is pretty handy, but with all these new circuit board appliances, it is a little more difficult to know exactly what we should or shouldn't do!
  • 6,784 Answers
Control senses oven temperature above 615F-630F
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Posted on Jul 23, 2009
My ge xl44 gas range, installed in 2000, turns off and flashes an f2 code occasionally. Can you give me the reason?
F2 means: For an unknown reason, the oven temperature has exceeded a preset threshold.
G.E. recommends you try this:
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737
Here is the fault code guide link:
http://www.geappliances.com/search/fast/infobase/10009792.htm
May 20, 2010 | GE Kitchen Ranges
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I can not find my manual for the range. I have a
Hi casharri,
Go Follow the link to get the manual =
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=ITEMID&itemid=49-85020
error F2 = Control senses oven temperature above 615F-630F
Regards
R.K.
Oct 15, 2009 | GE Spectra JBP78 Electric Kitchen Range
F2 Code Problem
I can't take credit except searching and found this info.. I will order to see if it fixes my error messages..Tom
All, I hope that this helps everyone having this annoying problem. The problem is the F2 error that seems to come on everytime you use the oven. Well, it was driving my wife crazy, so I finally gave in, and had a GE technician come over to fix it. :) It cost me $190, with $80 for the part and $110 for the labor. Had I known what the problem was, I could have fixed it myself in 10 minutes, and only would have had to buy the part. My loss is your gain. The technician replaced the sensor, part #WB21X5301 (can find at (www.geappliances.com (http://www.geappliances.com)); cost is $76. If you open the oven door, the sensor is on the top left-hand side and is long and skinny. Instructions come with the part to replace it. Basically, you unplug the oven, take out two screws, and cut the two wires to the sensor. You then use wire nuts to connect the new sensor wires, and push the :) wires out of the oven area into the back panel. That's it. Problem fixed. Glad I could help out others!! Merry Christmas! JakeDecember 11th, 2005, 02:25 PMThanks for the information and update back on this problem you had.:)
You can also buy that same part#WB21X5301 from here, abit cheaper:
Oven sensor assembly (http://www.repairclinic.com/referral.asp?R=1265&N=252618)
May 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven not working after controller beeping
if ihe oven is not working. ck ihe igeniter in side ihe oven it trun red hot when you trun the oven on
Dec 31, 2007 | GE JGBP33 Gas Kitchen Range
Ge gas oven/ranger xl44
The F2 is the code for the board seeing a temp higher than 600 degrees. It could be one of two things. The temp sensor is out of range, extreme high resistance. If you ohm it out it should read approx 1100 ohms at room temp. The other would be a welded bake relay on the board itself. Check the temp sensor first. If you are getting the F2 in the cleaning cycle, check the temp sensor, welded clean cycle contacts on the board or both contacts on the lock switch are closed at the same time. This is for the model posted JGBP90.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Range
It sounds like a thermal sensor is cutting it off.(a bad sensor,or wrong sensor)Is it a new range? Has it been repaired before?
Apr 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JGBP35 Gas Kitchen Range Logo
1,649 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
