Question about D-Link AirPlus DI-524 Wireless Router
No internet ok when i hook up my modem to the D-link it would work then a couple minutes later stop working...all the lights on the d-link are on except for the Wlan one and i would stay like that and never work plz help.. ps.i tried pressing the reset button then the staus light flashes but the WLAN does not and it would say i hooked up to my cpu but it would have no internet ty
  • 2 more comments
  • Sourabh_jg May 15, 2008
    My router works perfectly fine for some time. But after 45 mins to an hour, there is no transmission of the signal. I have to keep the router switched off for about 30 mins. Only then , after switching it on, it starts to work. Again the signal goes off after 45 mins.
    I need to repeat the process to make my router work.
    Can't this router transmit signal continuously? Do i have to switch on and switch off repeatedly to make it work? Please help....
  • Anonymous May 17, 2008
    i have my router but when conet the d-link no have internet
  • Anonymous May 20, 2008
    same problem
  • Anonymous May 25, 2008
  • 118 Answers
Try configuring it for typical setup from the manual . You can download it from
Posted on Nov 21, 2007
Can't get internet to work with dir-615 router for more than a day or two at a time
If you have more than one device hooked up to the router, when the problem occurs try pinging another device. If you are able to then the router is working fine and most likely the modem is flaky and needs to be replaced. The modem supplies the internet connection, the router just applies NAT so that more than one device and use your public IP address. If this turns out to be the issue make sure you contact your ISP for any special instructions. For instances Comcast requires the MAC address located on the bottom or back of the modem in order for your connection to work, other ISP use proxy settings. Century Link has no requirements.
Jan 22, 2012 | D-Link DIR-615 Wireless Router
Router works then knocks main computer off
internet service went dead and service was restored
Sep 13, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
We have actiontec verizon router/modem GT704WG. We have to reboot our computer and router multiple times a day to get the internet to work. It will be working, then all of the sudden it just stops, and we...
I have had this same problem with Qwest using a new iMac and MacBook on the Actiontec modem. Qwest did two things: first we reset the modem which was fairly simple and took only about 5 minutes. However, this fix lasts only a few weeks and it comes back. I have just ordered a new modem since there seems to be a problem with the Actiontec device with the newer high speed internet.
I'd try the reset before doing anything else. Good luck.
Jun 25, 2009 | Actiontec GT704WG Wireless Router...
I have a linksys wrt54g router. Lost power the other day and now router does not work with cable modem. All the settings are the same on the router, power, wlan, and internet lights are on. Tried to reset...
Check to make sure that your route has DHCP turned on.  Save your settings and turn everything off.  Power on you modem and wait at least one minute, if your modem has a link light, it should come on and stay solid once it connect with your ISP.  Then turn on your router and wait another minute for it to sync with your cable modem.  Finally, turn on your computer.  Remember that everytime that you plug something new into your cable modem, you have to reset your power.
May 03, 2009 | Linksys Wireless-G WRT54G Router
Can't get Linksys wireless router & RCA DCM 425 to work together
ok, ur old modem was configured for those two devices to work to gether
so u have to do the same here
*have ur modem connected directly to ur comptie
*go to ur command prompt if u have vista ( start * search * type cmd)
xp (run then type cmd)
the type in the screen that poped up ( ipconfig) enter
*look for default gateway type that in ur browser address
*should take u in ur modem interfase go to (advandced | PPPlocation | then set that modem on
BRIDGE MODEM and the modem should restart then connect router that should do it
rate my service please
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
Has my router gone bad?
If no power lights come on... it looks bad, but try another power adapter on the router before tossing it... could be that.
Jan 09, 2009 | D-Link AirPlus DI-614+ Wireless Router
Connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Jan 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Internet lights flashes then stops then flashes
its ok if the internet light on your modem is flashing. as long as its not off.
Aug 28, 2008 | Westell Wirespeed LiteLine 6100...
D-Link AirPlus DI-524 Wireless Router Logo
127 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
