Question about Victor CSR350D Oxygen Regulator
My oxygen regulator wont hold proper pressure. It just keeps going up.
    Problem Solver:
  • 5 Answers
Diaphragm needs replacing. Take it to the shop...this needs to be done correctly.
Posted on Jul 25, 2009
  • loft306
    loft306 Nov 19, 2013
    small fiber washer behind the diaphragm has failed sealseat.com manufactures the parts for most regulators and torches they also have exploded parts diagrams with part numbers.
  • loft306
    Let me add a bit, i wouldn't try to fix this yourself unless you can gaurentee that no grease not even grease from your hands gets into the regulator as it will explode when pressurized oxygen hits it.
Code P0171 i just cannot get rid of check engine light
What have you done? There are a lot of problems that can be associated with this. My first guess would be the oxygen sensor. Its hard to say for sure as I do not know what type of vehicle you have. But the other things can be mass air flow sensor, fuel pressure regulator, clogged fuel filter, fuel pump going bad, power control module, faulty injectors.
Your first step in diagnosing what is going on would be to check your fuel pressure and see what is going on. After that you can go ahead and check your oxygen sensor. Check the sensor's signal voltmeter reading. An oxygen sensor interprets an increase in oxygen as a fuel lean condition and emits a signal close to 200mV (0.20 V). If the sensor doesn't respond accordingly or takes time to respond, the sensor isn't working properly.
Apr 28, 2017 | Cars & Trucks
1994 Mercedes S600 right side engine has raw gas smell. Not the oxygen sensor.
I would check the fuel pressure regulator first,pull the vacuum hose off and see if there is fuel in the line,if so the diaphram has ruptured and raw fuel is being sucked into the intake
Dec 04, 2013 | Mercedes-Benz Cars & Trucks
Have changed to crankshaft sensor the oxygen sensor spark plugs and wire and wont start even when it is turning over
Borrow a fuel pressure tester from Auto Zone and test the fuel system. It could be that you have a bad fuel pump or fuel pressure regulator. It also could be a plugged fuel filter.
Mar 14, 2013 | 2000 Pontiac Sunfire
1995 isuzu pickup wont start sometimes
Fuel Pressure Regulator is located on the fuel rail.
1. Disconnect the negative battery cable.
2. Properly relieve the fuel system pressure.
3. Remove the air cleaner outlet tube(s).
4. Remove any necessary components to access the pressure regulator.
5. Disconnect the vacuum hose from the pressure regulator.
6. Remove the pressure regulator attaching screws.
7. Remove the pressure regulator from the fuel rail.
To Install
8. Discard the O-rings on the pressure regulator and replace them with new ones.
9. Lubricate the O-rings with clean engine oil.
10. Install the regulator into the fuel rail and tighten the retaining screws.
11. Connect the vacuum hose to the regulator.
12. Install any components removed to access the regulator.
13. Install the air cleaner outlet tube(s).
14. Connect the negative battery cable.
Jul 03, 2012 | Isuzu Pickup Cars & Trucks
Have electtric forced air 40.ooo, btu unit. have 10 psi regulator. am useing tank hookup from grill.wont stay lit.
I hope & pray, that the grill tank is not indoors with the heater. In any event, if you're using a grill regulator too, it's not going to provide the 11 to 13 water column inches of pressure that is required for 40,000 BTU's. That's why the heater wont stay lit. Nor, is it going to burn very long, as that grill tank only holds 2 gallons of gas
This is a gas appliance that is safe when installed and operated properly. Don't try to jury rig something that could come back to bite you in the end. Injuring or killing you and your family.
Feb 11, 2011 | Heating & Cooling
What is the fuel pressure for a 1996 mercury sable?
Fig. 1: Fuel pressure regulator exploded view
CAUTION Observe all applicable safety precautions when working around fuel. Whenever servicing the fuel system, always work in a well ventilated area. Do not allow fuel spray or vapors to come in contact with a spark or open flame. Keep a dry chemical fire extinguisher near the work area. Always keep fuel in a container specifically designed for fuel storage; also, always properly seal fuel containers to avoid the possibility of fire or explosion.
  1. Remove the pressure regulator attaching screws.
  1. Remove the pressure regulator from the fuel rail.
To install:
  1. Discard the O-rings on the pressure regulator and replace them with new ones.
  1. Lubricate the O-rings with clean engine oil.
  1. Install the regulator into the fuel rail and tighten the retaining screws.
  2. Connect the vacuum hose to the regulator.
  3. Install any components removed to access the regulator.
  4. Install the air cleaner outlet tube(s).
  5. Connect the negative battery cable.
Hope help with this (remember rated this).
May 28, 2010 | 2000 Mercury Sable
Maytag Range/Oven Model MGR5770ADQ: Oven burner lights, then flame shrinks and grows erratically - very slow to heat properly.
Just inside your range where the gas hooks up oyur will find a gas pressure regulator. The job of this device is to let the gas through to your ange evenly and at the right pressure to keep everything workiing properly. This device is surging, meaning that it is opening and shutting erractically instead of holding a steady pressure for you.
Replace that gas pressure regulator and you will be fine.
Heatman101
Jan 19, 2010 | Kitchen Ranges
Victor CSR350D Oxygen Regulator Logo
473 people viewed this question
Top Victor Welding Tools Experts
Bill Boyd
Are you a Victor Welding Tool Expert? Answer questions, earn points and help others
