Question about Konica Minolta magicolor 2430 DL Laser Printer
Huge HP scanner files
I have an HP G85 xi. When I put documents on the feeder and scan them , they end up as huge files. When I try to set the dpi to a reasonable size, they come out grainy and pixellated. (My faxes are better quality and have sharper resolution than the scans).
Is there some setting I am missing, or does this model HP not perform well on document scans.
  • 164 Answers
Could be you are scanning pictures of documents and not doing OCR..Optical Character Recognition
Posted on Jul 24, 2009
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Text being scanned does not produce a clear print to our cannon ip18oo printer
alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
Aug 13, 2008 | HP Office Equipment & Supplies
We are having HP Officejet J4580 all in one in our office. but the problem is that even if i scan a document in gray scale & PDF then also the file size come out to very Huge; Which troubles us alot...
Scanning in gray scale alone will not bring down the scannned documents size alone. In your scan settings there should be a setting whereby you lower your DPI (dots per inch) or scan resolution. The standard DPI is usually about 300. Try lowering it to about 100 and check the scanned document size again. Lower your DPI until you reach the appropriate document size for emailing etc.
Best wishes,
Graemevm
Jul 26, 2011 | HP OfficeJet J4580 All-In-One Laser...
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    How do I scan a document into a pdf and send by email
    hi,
    HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.hp.com/printer/prob676ijt65/solution
    astrtr21
    Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
    Scanned files are too big
    Change the file format its saving in. different formats have different compression rations. Jpg images are smaller than bmp images. simply by changing it to jpg it will be 20 times smaller. To do this when click save and the save image box appers, in the format type select jpg or gif or what ever is avilable. Play around to see what gives you the smallest size. You can also use software like Photoshop, paint, and other image editors to change the format its being saved in.
    Dec 16, 2008 | HP LaserJet 3380 All-In-One Printer
    Huge pdf files
    Try scanning a "photo" to file and using the advanced scan options to set a lower DPI. Then from the Library view you can convert that 'photo' (of a document) to PDF.
    Steve
    Sep 05, 2008 | Lexmark X7350 All-In-One InkJet Printer
    Lexmark X7350 Scan feature
    well you are able to scan multiple documents.. but the file size is more.. the way lexmark software writes the pdf file.. the file will be huge for PDF... but not sure if this is a case with any other all in one manufacturer like HP also... but i would assume it would be the same.. so scan the file to MS WORD or any other application that supports multiple pages... so u have it as one file... but if u want only pdf files, then u have to do a little work around like writing the MS WORD Document to pdf format. If the PDF Writer is not installed with your copy of MSWORD then try any free pdf writer software available on the internet.
    Aug 31, 2007 | Lexmark X7350 All-In-One InkJet Printer
    Konica Minolta magicolor 2430 DL Laser Printer Logo
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    David Burkhart
    David Burkhart
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
