Question about HP LaserJet 4600dn Color Printer
Get an error message 82.0180 EIO 2 Error.
Printer will not print documents.
  • 40 Answers
Plug network card again, after try to change theother, because ROM card error
Posted on Jul 24, 2009
2 Suggested Answers
TerryTown
  • 292 Answers
SOURCE: My HP 4100tn will not
Thank you for contacting FixYa with your printer inquiry.
This is an error caused by the jet direct card in your printer, try one of two things.
  1. Move the Jet Direct card from port 1 to port 2 on the printer.
  2. Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
The problem is usually a faulty card.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Posted on Jun 13, 2011
Error 49.23F9
. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 19, 2014 | HP CP3525N Color LaserJet Printer
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
How solve error 49 on 4730mfp
it's a long one !
Dec 18, 2012 | HP LaserJet 4730mfp All-In-One Printer
49 error
49 error means firmware error..
solution:
3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certain print job, try upgrading the printer driver and / or firmware.)
5. Remove all EIO devices from the printer (Jet Direct cards, hard drives, etc.). If 49 errors goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing.
6. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
9. If error persists, replace the formatter.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | HP LaserJet 3055 All-In-One Printer
Error 49.4c18 laserjet3800dn
49.XXXXX ERROR A critical firmware error has occurred.
1. Turn the printer off and then on.
2. Try printing a job from a different program. If the job prints, try printing a different file from the original program. If the message appears only with a certain program or print job, contact the software vendor for assistance.
3. If the message persists with different programs and print jobs, disconnect all of the printer cables that connect to the network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install each DIMM and EIO device one at a time. Turn the printer off and then on again after installing each device.
9. Replace DIMMs and EIO devices as necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware DIMM.
12. Replace the formatter and calibrate the printer.
Jul 20, 2011 | HP LaserJet 3800 Printer
49 ff95 service error for hp 5200n LJ
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other
causes include poor-quality parallel cable, poor connections, or home-grown programs.
2. Press Stop to clear all print jobs from the printer memory.
3. Turn the printer off and then on.
4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message only appears when using certain software programs, contact the software program vendor for assistance.
5. If the message persists with different
software programs and print jobs, disconnect all of the cables and turn the printer off.
6. If the error persists, perform a firmware upgrade.
7. Remove all DIMMs, EIO devices, and CompactFlash solutions.
8. Remove all EIO devices.
9. Turn the printer on.
10. If the error does not persist, reinstall the DIMMs, EIO devices, and CompactFlash one at a time.
NOTE You must turn the printer off and then on when reinstalling each component.
11. Replace the DIMM, EIO device, or CompactFlash if necessary.
12. Reconnect all of the cables.
Jul 16, 2011 | HP LaserJet 2420dn Printer
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Vender
Feb 22, 2011 | HP LaserJet 4100n Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Error 49.4C2D
3. Try printing a job from a
the job prints, go back to the first
application or print job, contact
assistance.)
5. Turn the printer off.
6. Remove all memory DIMMs or
firmware DIMM in the lowest
DIMM slot.)
7. Remove all EIO devices from
the printer.
8. Turn the printer on.
9. If the error no longer exists,
device one at a time, making sure
to turn the printer off and back on
as you install each device.
10. Replace a DIMM or EIO
device if you determine that it
causes the error.
11. Remember to reconnect all
12. If the error persists, replace
the firmware DIMM.
13. Replace the formatter.
Nov 09, 2009 | HP LaserJet 4100dtn Printer
ERROR MESSAGE
This error is usually caused by a bad formatter board.
But try the following:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Dec 13, 2008 | HP Hewlett Packard LaserJet P3005n Printer
HP LaserJet 4600dn Color Printer Logo
1,096 people viewed this question
Seeker5211
Seeker5211
