Question about Honeywell HZ614 QuickHeat Baseboard Heater
When i plug the heater in it does not work.
I have a honeywell Hz614 quickheat baseboard heater. model # Hz614
when i plug it in nothing happens.
  • 625 Answers
Its difficult to make a homeowner an expert in troubleshooting his/her equipment if he/she has no technical background - but - I will try. First check the cord to plug connection. Is it tight? Does it look melted? Next, take the unit apart where the cord goes into the unit. Check the wiring path. Look at each connection. Look for burnt off wires at connections. Most connectors are the push on type and are mechanically fastened to the wires. if they are burned off you'll need replacement spade terminals and a crimping tool. (radio shack) has these. one wire will go through a thermostat and out to an element terminal. one wire may go through a thermodisc overload, then to the thermostat and then to the element. the other wire will definitely go straight to the element. there may be some extra connections for lights etc. if you have to take apart the heater make a diagram of which wires go where. use some masking tape with numbers written on it to make sure the wires go back to the same place you took them off.
Posted on Dec 07, 2007
Not heating up... what could be problem....some simple i hope
How about a free replacement heater?
There has been a recall since 2002 on some Honeywell portable baseboard heaters. Check this link, or call Honeywell ASAP. The ON/OFF switch failed (with a burning plastic odor) on my HZ-514.
http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/
"Consumers should stop using these heaters immediately, unplug them, and contact HCP at (800) 290-8495 between 8 a.m. and 10 p.m. ET Monday through Sunday or log on to the company's website at www.honeywell.com to determine whether their heater is part of the recall."
I hope this is a solution for you, and you are safely warm again in the near future.http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/ not-heating-up-could-problem-some-gwybjxudtwjfkyidrgix5fxs-4-0.jpg
Oct 23, 2013 | Honeywell HZ514 Baseboard Heater
Need to replace off switch
I hope this is a solution for you, and you are safely warm again in the near future. need-replace-off-switch-gwybjxudtwjfkyidrgix5fxs-5-0.jpg
Mar 12, 2013 | Honeywell HZ514 Baseboard Heater
Off switch
I hope this is a solution for you, and you are safely warm again in the near future. off-switch-gwybjxudtwjfkyidrgix5fxs-5-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Need a thermostat for model no hz-514
I hope this is a solution for you, and you are safely warm again in the near future. need-thermostat-model-no-hz-514-gwybjxudtwjfkyidrgix5fxs-4-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Feb 03, 2013 | Honeywell HZ514 Baseboard Heater
Honeywell Hz614 quickheat baseboard burnt switch
Yes more than likely just get a MAINS RATED switch.It MUST have it printed on it. Check passed the switch too, make sure you don't have "Other" problems, try to determine WHY the switch "Burnt Out"? In saying that though, they DO, have this happen spontaneously sometimes. Be careful.
Feb 13, 2010 | Honeywell HZ614 QuickHeat Baseboard Heater
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Need to replace 2 wire baseboard thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 13, 2009 | Honeywell (CT62B1015) Baseboard Heater
Wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Nov 27, 2007 | Ingram GMS90904CXA Heater
Honeywell HZ614 QuickHeat Baseboard Heater Logo
123 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
