Question about HP Officejet Pro L7680 All-In-One Printer
Hp Officejet L7680 Self Test Diagnostic Page says everything good
When unit did print it only printed half of the letter the rest was missing. First time I printed Test Page came out black now it is pink. The ink levels show almost full even changed the black cartridge but did not change anything. Even Log
ID shows 42 39 38 37
Event shows 69540 69540 69552 69540
Printhead health GOOD on both
SOURCE: HP Officejet L7680
i say change the print head an the cartrige an that should be find
couse i did an my printer is perfect
by andrew
Posted on Apr 04, 2008
technotech
  • 183 Answers
SOURCE: HP L7680 print head problem
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Posted on Aug 19, 2008
Joed911
  • 4338 Answers
SOURCE: Printhead(s) Problem
Here is HP's link on how to diagnose the problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01628836&cc=us&lc=en&dlc=en&product=2512009
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 06, 2009
  • 8 Answers
SOURCE: HP Officejet Pro L7580 ADF will not pick up paper
You can lift the top of the unit to inspect the rollers. Be careful because the L series the roller can pop off easily and if you're not paying attention to original orientation, can be a pain to put back in.. you press the blueish button to release the pick up assembly. See if any rollers are dusty. If they are, use Isopropyl alcohol (highest % you can find) and a LINT FREE cloth (dryer sheets/coffee filters or something of that nature..) and wipe clean
Hope this helps, I'm honestly doing all this from memory, I used to work for that dept here in Oregon ..
Posted on Sep 08, 2009
  • 7 Answers
SOURCE: HP L7680 won't print black, cartridge is new, says
Try printing a Diagnostic page or clean cartridge. Looks like the printheads might be clogged due to low usage or general wear and tear, they may not be working as desired.
Posted on Oct 26, 2009
We are having problems with our Office Jet 7310, for example when we print a document on every other line the bottom of the g's are cut off and the rest of the characters on the line are faded at the...
To determine what the problem is run a self test page. Push the "Setup" button then choose option 2 then option 5. This will print a Self test report page.
For more detailed information (assuming you did a standard install) go to "Start", choose "All Programs", choose your HP menu option, choose "OfficeJet All-In-One 7300 series", choose "Help". Once your in Help scroll down to "Maintain your HP All-In-One", open the sub-menu and choose "Clean the HP All-In-One". On the main help page sellect "Print a Self-test Report". This should tell you just about all you need. Good Luck!
May 31, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Missing text and top of some text is missing
* Perform Step 2 in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01446637&cc=uk&lc=en&dlc=en&product=3643612
If the issue persists, please print a self test page from the unit and verify whether the unit prints the test apge fine. Step are given below:
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.
:) Dr Tony
Apr 20, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
HP L7680 won't print black, cartridge is new, says it is full, Self diagnostic page says printhead is good
Oct 26, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 When printing a power point presentation, lines are printing over the jpeg pictures on the slide
There is some problem with your print heads. Run a print diagnostic report and see if it helps. You also may want to trigger clean cartridges if triggering print diagnostic page does not help.
This issue may happen if the printer is not used for few days. Recommend to keep the printer powered on always, or then trigger print diagnostic page as it tries to unclog the blocked print heads to give you a clean print.
Hope this helps.
Oct 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 prints half page only
to get to the root cause of the problem . you can try printing from the notepad and check it prints fine from the notepad . if it prints fyn then there can be some issues with the software compatibility.. which version you have for microsoft office.
Oct 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
My C5180 won't print. It sounds like it is printing but spits out a blank page
>try the steps on this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01449854&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1153481&lang=en
.also check if there is still ink on it try printing a self test page
Method one: Print the page from the control panel
  1. Load letter, A4, or legal, unused plain white paper into the main tray.
  2. Press the OK and Help buttons at the same time and then release them. The self-test diagnostic page prints.
Method two: Print the page from the computer
  2. Open HP Solution Center.
    • Windows Vista: Click the Windows icon (c01364735.gif ), click All Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click the Settings menu, point to Print Settings , and then click Printer Toolbox .
  4. Click the Services tab, and then click Print test page . The self-test diagnostic page prints.
Oct 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
The last line of every document is cut off and the bottom half is missing as though the margin isn't long enough, but that's not the case.
Try to print a self test page using the below steps
  4. Press OK . The self-test page prints.If this prints fine, perform the partial reset of the printer using the below steps:
    1. Unplug the power cord from the HP All-in-One.
    2. Wait for 20 seconds.
    3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
    4. Release the buttons after the HP All-in-One starts up.
    5. The HP All-in-One will now be reset to factory defaults.
Sep 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP all-in-one not printing cyan color
Place a soft clean tissue paper over the cartridge print head and leave for about eight minutes. You can secure it with the aid of a rubber band. It should be held firm ok. If the tissue paper is not dampened by ink then the cartridge would have gone bad or the ink dried. You also know that they have expiry date and could go bad while yet in the packaging b/c it has expired. Good luck
Jun 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
Number of pages my printer has printed
You need to print a self diagnostic page. On that page will be listed the number of pages printed from trays and accessories.
To print the Self-Test Diagnostic Page
• Control panel: Press Setup, select Print Report, select Self-Test Report, and
then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print Self-test
Diagnostic Page.
• HP Printer Utility (Mac OS): Click Device Information from the Information and
Support panel, and then click Print Configuration Page.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
681 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
