Question about HP PSC 1210 All-In-One InkJet Printer
My 1210 printer is plugged in, cartridges have been cleaned, paper is in correctly and the printer is active but it will not print. Suggestions.
  • Bruce Hathcock May 11, 2010
    did you try to go to printers and select it as the default printer and is it a usb printer cable? if it is unplug it and plug it back in and see if windows see it I also need more information to help more. just post here for more information.
  • HP Master
  • 5,340 Answers
Have you checked the printer spooler on your computer? I have seen jobs stack in the queue following an error and get "stuck"; these stuck jobs don't even leave when the computer is rebooted. On most Windows OS's (I haven't tried Vista), you can delete the contents of the spooler from the command prompt faster than other methods. Type "Net Stop Spooler" (without the quotes followed by hitting enter) followed by "Net Start Spooler" (same thing). That will completely clear the spooler and you can retry sending something to the printer. You can also do the commands from the Run command line but then you need to take a long coffee break after restarting the computer after the first command.
Posted on Jul 23, 2009
    President:
  • HP Master
  • 1,996 Answers
You don't mention what OS you're using, but have a look here, and see also the solve a problem section of your home support page here. Frequently this is corrected by clearing the print queue and rebooting the system. Sometimes it is also necessary to reset the printer, in which case see this article.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
The ink cartridge was replaced, but it won't print all of the typed words and those is does print are not clear. How do I replace the cartridge correctly?
It is the print-head that sprays the ink onto the paper that is partially clogged. So, you get "white-lines" across some lines on a page. Run the HP Printer Assistant, and do a "head-cleaning" cycle.
Sep 22, 2010 | HP PSC 1210 All-In-One InkJet Printer
How do I clean the printer nozzles as it leaves streekes on printed pictures?
If the ink is smearing, it probably is not getting enough drying time. The ink drying time is a period of time inserted between pages to reduce the chance that a page will smear the one below it in the output tray. This time is factored into the time between when the first page finishes and when the next page finishes. Printing will pause temporarily if more time is needed. The time it takes for ink to dry varies greatly depending on paper type, printer driver settings, humidity, and temperature. In addition, the paper and print settings may affect the speed at which the ink can dry:
  • Transparencies require much longer drying times than other paper types.
  • Some store-branded photo papers do not allow ink to dry correctly because of the coatings used in their manufacture.
  • Printing in Best mode can increase the dry time.
Resolving the problem If the ink smears, increase the drying time. To increase the drying time in Windows, follow the steps below:
  1. When ready to print, click File , click Print .
  2. Depending on your driver version, click Properties , Settings , or Preferences and follow the steps below depending on the option.
    • For Properties or Settings , follow the steps below:
      1. Click the Advanced tab.
      2. In the Extra Dry Time section, move the slider toward More .
    • For Preferences , follow the steps below:
      1. Click the Basics tab.
      2. From the Basics tab, click Advanced Features .
      3. In the Extra Dry Time section, move the slider toward More .
  3. Try a sample print and see if the drying time needs to be increased more.
To increase the drying time for a Macintosh computer, follow the steps below:
  1. From the File/Print Menu , select Ink under the General tab.
  2. In the Dry Time section, move the slider toward More .
Other steps that will reduce ink smearing If the ink still smears when printing, try some of the following suggestions:
  • Decrease the amount of time it takes for the ink to dry by decreasing the print quality to Normal or Fast mode.
  • Try printing on a different type of paper or on paper from another manufacturer. Paper formulas are different between manufacturers and may have a coating that causes the ink to be absorbed at different rates.
  • When printing large graphics or photos on plain paper in Best or Normal modes, improve the results by using heavier paper. Paper that is rated at 90 g/m2 (24 lb.) or higher will not curl or smear as easily as paper of a lighter weight.
Mar 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Check cartridge check print paper light and
remove color or black cartridge, close the lid, let the printer initialize, and then reopen lid and add 2nd printer cartridge...
this should sove the problem
Nov 30, 2009 | HP PSC 1210 All-In-One InkJet Printer
Having an issue with my ML 1210. It prints these
The roller had an ink spot it it which is transferring to the paper. clean the roller carefully with some rubbing alcohol on a clean cloth. then let it air dry for 30 minutes before using it. Have the printer unplugged while you do this and use a minimal amount of alcohol, just a damp cloth will do the job.
Oct 02, 2009 | Samsung ML 1210 Laser Printer
Hp12..it says chek print cartridge..they are
Run the clean printhead routine from within your printer software
Sep 27, 2009 | HP PSC 1210 All-In-One InkJet Printer
My hp psc 1210 all-in-one printer won't print
I am having the same problem as we speek! Solution....throwing off the deck!
Apr 08, 2009 | HP PSC 1210 All-In-One InkJet Printer
Having problems printing after changing ink cartridges.......scanner and copier work fine.....when send the command to print from the computer...it pulls the paper and sounds like it's printing but just...
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 06, 2009 | HP PSC 1210 All-In-One InkJet Printer
Check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
PAPER JAM
SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
SEGGUSTION #2 cleaning rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  1. Turn off the all-in-one and unplug the power cord.
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
Jan 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
118 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
