Question about Epson Stylus C88 InkJet Photo Printer
Epson c-88 won't feed paper
Hello, my c-88 won't feed the paper through...it was feeding reg paper no problem but then I put in my transfer paper, (which I have used for over 2 years with another c-88) I need help, I have got shirts that need to be done tomorrow..thanks a million
    President:
  • Epson Master
  • 990 Answers
Hello sir; You may go to computer to set up; Hit print then go to preference then paper/quality then you can choice the type of the paper you want to print, good luck.
Posted on Jul 23, 2009
Paper feeding problem
You need to replace the feed and transfer rollers. They dont cost a whole lot
Dec 23, 2013 | Epson STYLUS SX235W
I checked the steps on your Epson R340 Paper Feed problem. Both of our R340s are about a year and a half old and they are both having the same problem. There is nothing wrong with the paper . . . it...
hello, eventually the feed roller will need to be cleaned, it collects paper dust and dust and inks, so becomes smooth, and unable to grab paper properly, cleaning with alcohol, yes it does clean but dries rubber, WD-40, is waht i use, but i allow it to be absorbed into roller, then wipe off the excess, then try feeding paper.
Oct 14, 2010 | Epson Stylus Photo R340 InkJet Printer
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    Epson multi fuction printer will not pull the paper in when faxin
    Red Light remains on, it make a noise. but nothing happens
    Feb 16, 2009 | Epson Stylus CX9400 Photo Printer
    Epson cx3800 paper feed problem
    no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
    Jan 29, 2009 | Epson Stylus CX3800 Printer
    Paper will not load into my Epson PHOTO R340 printer.
    May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
    Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
    Cannon copier
    Where is the machine saying the jam is located? Does the paper even start to feed? Does the paper feed to the next feed area? If the machine sounds like it is feeding ( trying to feed) and the paper is still in the tray --- clean the feed roller/ tire with rubber restorer or a high alcohol base cleaner. IF the paper is fed part way out of the tray to the long ( most of the time) black reg. roller and now farther --- clean the reg. roller. There is always the chance that you have a bad feed motor or reg. motor. Also look to see if an actuator / switch has been pulled / knocked out of position. They is is small cradles and can be snapped back into place.
    REG = registration
    Jan 06, 2009 | Office Equipment & Supplies
    Print head alignment +won't feed paper
    Best solution is to clean the head with it in place,here's
    the manual for your printer
    Oct 09, 2008 | Epson Stylus Photo R2400 InkJet Printer
    Epson Photo RX600 error messages
    Hi.
    Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
    Goodluck... Fixya me...
    Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
    Epson Stylus C88 InkJet Photo Printer Logo
    151 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
