Question about GE Profile WPRE6100G Top Load Washer
Washer won't fill with water
Washer makes a humming noise but nothing happens. Doesn't matter temperature or wash setting. Worked fine a week ago, the last time I did wash. tried disconnecting power to re-set and didn't help.
    President:
  • 1,776 Answers
A water level switch regulates the washer's fill volumn. The switch is usually a diaphragm like device with a small clear tube attached between the switch and the bottom of the washer's outer tub. It works on water pressure on the air in the tube. The switch can be tested using an ohm meter or multimeter. The switch should have continuity. If not, it is defective and will need to be replaced. Hope this helps and best wishes.
Posted on Jul 23, 2009
  • Bruce Canfield
    Bruce Canfield Jul 23, 2009
    This is the water inlet valve solenoid assembly that was mentioned by the other expert. Hope this helps and good luck resolving the problem.
    Top Expert:
  • GE Master
  • 76,164 Answers
Replace the water inlet solenoid valve
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Crosley washer won't agitate
Hello Carroll Mcknight - Is the washer making a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the unit may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to assist with the repairs and to move forward accurately.
Jan 22, 2013 | Washing Machines
Whirlpool lsb6000pq2 washing machine won't fill with water
Humming could be a blockage on the fill solonoid valve remove water fill hose and clean the filter at the valve it pulls out or use an old toothbrush
Jun 26, 2012 | Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Washing machine wont fill with water, just hums. Spin works fine, just wont fill with water.
The humming noise is caused by the water valve solenoids trying to open. You will need to remove the hoses from the back of the machine and see if there is any calcium or water deposit on the screens in the water vavles. If there is try cleaning it out and testing, if there is none, the water fill vavle will need to be replaced, you can order parts for it at, Reliable Parts by using your model number. Valve should cost around $45. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 19, 2010 | Whirlpool Washing Machines
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Maytag alantis MAV 9600
hi thanks for the question re set the water level control to see if it will add more water if it doesn,t it could be a bad water valve check that thanks the appliancedoc
Sep 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
151 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
