SOURCE: Iron heating sporadically and sensor lights working sporadically
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
SOURCE: Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
SOURCE: Rowenta iron DX1700 not heating
I hate to say this but I came here looking for solutions and it seems the solution is not to buy this Rowenta overpriced products.
SOURCE: SHARK IRON WITH TANK.GREAT BUT SUDDENLY STOPPED.
these along with coffeemakers have a thermal fuse for safety the fuse looks like a cilinder with one flat side and the other side pointed with a wire protruding on both sides. it is located inline with the heating element under the cover "Appliance Parts" on the internet sells the part
SOURCE: My iron stooped working all of sudden.
If the input led is not glowing it means the connection to the mains inside your iron has got disconnected. Just open the iron. Check the input on the mains and check all the three wires are connected properly. It will heat again. When you were changing to cotton. You asked more voltage to the heating element and possibly due to more voltage the connection got broke and now the circuit is incomplete hence no led and no heatup.
Testimonial: "Thank you very much dear.You saved my money otherwise i was going to buy another iron. Your solution worked very well. "
