Question about Kensington Staffords Kensington StafCar Mount fords K33412US
'99 Expedition was recovered but ignition was tampered, still have keys to start car but fuel pump doesn't seem to turn over?
  • 85 Answers
Need to reprogram the keys at a ford dealer and could have a bad transponder on the steering column !!
Posted on Mar 31, 2010
99 Ford Expedition will turn over, but will not start. I changed the fuel filter and the pump is working.
Spark at the plug? Could be coil/s, ignition module, or the crank sensor. Check fuses first. Pull them and look, in case the are corroded.
Feb 10, 2015 | Ford Cars & Trucks
99 expedition my fuel pump isnt working checked fuses is there a fusuble fink with key on the fuel shutt off switch behind right kick panel has no power to any of the wires?
Power comes from a fuseable link to the pump relay, then to the inertia switch on the dark green and yellow wire. Power from the inertia switch to the pump is on the pink blue or pink black wire.
Jan 20, 2014 | 1999 Ford Expedition
Fuel pump sometimes works and sometimes does not turn the key a couple of times and pump goes on
My 99 grand am also has this issue. I'm not sure if they are the same issues but in my gran am if you turn the key too fast from on then to start the fuel pump doesn't prime. Try turning the key on then start somewhat slowly. Hope this helps.
Aug 25, 2012 | 1999 Ford Windstar
I have a 99 ford expedition and my fuel pump stop pumping Trying to find the fuel pump fuse do not have owners manuel Where is the fuel pump fuse
Here is the manual
FUEL PUMP SHUT-OFF SWITCH After a collision, if the engine cranks but does not start, the fuel pump shut-off switch may have been activated. The "Fuel Reset" indicator light will illuminate in the instrument cluster. The shut-off switch is a device intended to stop the electric fuel pump when your vehicle has been involved in a substantial jolt. 1. Turn the ignition to the OFF position. 2. Check the fuel system for leaks. 3. If no fuel leak is apparent, reset the fuel pump shut-off switch by pushing in the reset button. 4. Turn the ignition to the ON position. Pause for a few seconds and return the key to the OFF position. 5. Make a further check for leaks in the fuel system.
The fuel pump shut-off switch is located in the passenger's foot well, behind the kick panel.
Mar 08, 2011 | 1999 Ford Expedition
2002 Ford Expedition Fuel pump relay clicking when key turn to on and won't start do not get any readings upon connecting a computer reading check. also on gauges theft is blinking on and off. if i...
possible fuel pump shorting out problem, disconnect fuel pump wiring connector located around tank area under vehicle & turn key on again. if no more clicking from relay or theft warning stops. then change fuel pump, and check the short wiring harness to fuel pump for overheat signs.
Jan 15, 2011 | 2002 Ford Expedition
My theft light is flashing but my 1997 expedition wont start.The vehicle turns over but just don't start.
ANTI-THEFT SYSTEM Passive anti-theft system
Your ignition key has a unique imbedded transponder which engages engine electronics and allows the vehicle to be started. Without the use of your special ignition key, the vehicle will not start.
During each vehicle start, the coded key is read by the anti-theft system. If the key’s ID code matches the code in the anti-theft system, the vehicle is enabled to start.
Anti-theft system
Briefly illuminates when the ignition is turned to the ON position to verify that the passive anti-theft system is operating properly.
Also, its possisble that tou have actovated the fuel pump switch.
CHeck it.
Jul 20, 2010 | 1998 Ford Expedition
My 99 Expedition just died while driving. After towing it home it now wont even turn over. I can jump the starter and it engages and I have power to dome light and headlights but when I turn key nothing (...
I has an 86 Mustang that did a similar thing and it turned out that the battery actually shorted out. This happens when one of the plates inside the battery brakes off and then touches another plate. When mine died it was like I turned the iginition off. It wouldn't turn over even with jumper cables.
Oct 18, 2009 | 1999 Ford Expedition
99 buick regal won't start
Hello, the Regal seems to have that problem. Insert your key in the ignition and turn it but do not turn the car on, make sure you here the fuel pump kick in, then at the end of you r fuel rail there should be a cap, remove it, use a very thin screw driver and push that part in, Be careful it's going to squirt gas, that's a good sign. If it does not, check your fuel filter. And last, if nothing above described works first check your negative wire on your fuel pump, second your injectors, they might be clogged.
Best of luck, God Bless.
Willie
ECSracing Team
Aug 14, 2009 | 1999 Buick Regal
1999 hard starting expedition, with 5.4 engine
fuel pump may be going. try this. turn key on, listen for fuel pump to run for 5 seconds. Turn key off, wait 15 seconds or until you hear relay click inside car. Turn key on again for 5 seconds and ff for 15 seconds. repeat once more. This will pressurize fuel system to 40 psi so injectors have full pressure. If it starts quickly now, you are getting bleed down through the check valve in the fuel pump or the fuel pressure regulator on the fuel rail.
Jun 30, 2009 | 1999 Ford Expedition
I have to turn the ignition on and off several times before the car starts. Recently replaced water pump after car overheated. Could coolant have caused the issue?
Replace fuel filter if it has not been done in a while. Also check fuel pump pressure with a gauge and compare with spec. When key is turned "on" the computer turns on fuel pump via relay. If the computer does not see rpm signal (engine start) within approx. 2 seconds it turns the fuel pump back off. Cycling the key often helps to build up fuel pressure sufficient to start when filter is plugged or pump pressure is weak.
Jun 29, 2009 | 1999 Ford Expedition
Kensington Staffords Kensington StafCar Mount fords K33412US  Logo
35 people viewed this question
Top Kensington Staffords Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kensington Staffords Audio Player and Recorder Expert? Answer questions, earn points and help others
