Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE build-in sideby side fridge problem
I have a GE build in side by side refrigerator. I just found some water underneath the fruit bin on the refrigerator side. I could not find out where the water come from. Could anyone help me?
  • GE Master
  • 4,654 Answers
This is a common problem when the defrost condensate drain becomes blocked. Below is a link that tell more about what is happening. Sea Breeze
Posted on Jul 25, 2009
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Refrigerator collecting water under veggie bins in my side-by-side GE fridge/freezer. This has been happening for months and I have to wipe up water everyday. Now my freezer and fridge are going up about...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Side by Side (model GSL22JFRJBS) and am having several problems and I'm not sure if they are connected or if I just have bad luck. 1st: the freezer and fridge are not staying cold. The freezer...
HI change the main board its about $150-200. Will fix all your problems except the lightbulb would be a lightsocket problem or the bulb you put in is bad, or door switch.
Sean
Mar 30, 2011 | GE GSL22JFPBS Side by Side Refrigerator
Water overflowing in ice maker tray on a GE
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Mar 13, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Water laying underneath the fruit & vegetable storage drawers
Hi Matt, Hi Dar(lene)?
Super easy fix. Your defrost drain is blocked by what we in the biz affectionately refer to as "Bio-Gookus", so every time the fridge goes into defrost, the newly melted water has no place to go other than the bottom of your fridge. Gravity is what gravity is, ya know?
My bet is that it's clogged up at the drain funnel located in the refrigerator/beer compartment. If I'm remembering right, it should be just to the left of the thermostat/control panel in the back. You should see a plastic cover there, remove it. See the "Bio-Gookus? Kinda gross, huh? All of that has to be cleaned out. Not only in the funnel but the tubing behind it as well.
After cleaning it (and putting the pieces back) your fridge will be happy again.
Hope this helps!
SG
Mar 23, 2009 | GE Refrigerators
Drain pan under ge sideby side fridge
pull the front bottom grill off then pull the pan out to you to drain or cleas.
Dec 16, 2008 | GE GSS25JF Side by Side Refrigerator
Refrigerator has water underneath vegetable and fruit bis. It seems like an air flow situation
We found that the drainage for the defrosting was plugged. The water from the freezer drains from a hole that's on the top of the fresh food unit. There's a gutter that shunts the water to a tube that runs to a tray underneath the refrigerator. The tray was bone dry. So we unscrewed the gutter from the top of the fridge, and yes, it was plugged. Some Scrubby bubbles later, the plug was done. We reinstalled it, and now we don't have water underneath the vegetable/fruit bins.
This is for the GE TBF15DC For other models, your mileage may vary.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
206 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
