Question about Iomega 1TB Desktop USB 2.0 Hard Drive
I have an iomega exteranl hardrive whic i can access on my Mac laptop, but when i connect the drive to my my windows based laptop, it's not accessable
  • spx09 May 11, 2010
    did you format it with your apple? i think apple doesn't use fat32 or ntfs so there should be the problem. but as i don't know much about apple i post this as a clarification request.
  • 284 Answers
I not a big mac expert but it is probably to do with the way your portable drive is formatted. Windows pc's will recognize drives formatted as FAT32 or NTFS. Mac's will also recognize these formats. If the disk was originally formatted with a mac format like HFS is won't be recognisable to windows. Connect it to your mack and look for the Fike System Type. You could back up any files you have on the portabe device to your mac hard drive then format the drive on a windows machine. Start with a NTFS partition and see if your mac can read and write files to it. If not then try again with fa32. Once you have it going you can put your saved files back. Hope this helps. Let me know how you go.
Posted on Jul 24, 2009
I used my Iomega GDHDU on my windows computer, but I now have a Apple Mac, however I can't access my hard drive as it is coming up as read only on my mac. how do I alter these settings so I have full...
You will have to copy the data from the Iomega drive.
You will then need to format the hard drive using the mac operating system so that the mac can read the file system. Unfortunately this means that you will not be able to use the iomega in Windows-based systems in the future.
Alternatively, copy the data off, and format the hard drive in a Windows environment using the file system FAT32. Mac operating systems can read this format. :)
Sep 15, 2011 | Computers & Internet
My laptop does not recognize my iomega hard drive
You need to format your drive to work with your Mac. The drive is shipped formatted as NTFS (Windows).
I'm going to assume that you are using Mac OS X 10.5 or later.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive.
********Make sure you click on the high level icon, not the second level volume icon.********
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Dec 17, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Iomega 1TB HD Works on iMac but not on Windows Laptop?
as the mac has a diffreent format to a pc you cannot connect up the drive to a pc because it simply wont recodnise it. the best way is to network the 2 computers together then alow file sharing on the mac and searcc with windows through the network to find the drive. then copy them across the network to your pc. this will then reformat the files to PC files at they hit your PC
May 17, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hi.my Iomega external hardrive is not recognised in my computerbut it is on my main computer. I have cleaned my laptop after it was corrupted to it's original state and now it works as normal. but still...
If your drive came with an installation cd I would recommend that you install that first and then try to connect your hard drive after the disk installation, it should then be recognised. What version of windows are you using? It should be recognised by xp. Good luck. Andrew
Jan 18, 2010 | Western Digital My Book Essential Edition...
Format Problem???
hello!
Try running it on win XP ,you have to install win XP on your pc or any other program to access the harddisk .
good luck
Oct 06, 2009 | Western Digital My Book Essential Edition...
External hardrive not being reconized by computer
There's are a couple of registry patches for Window's users for unrecognized external devices. Install the patches from the links below.
http://support.microsoft.com/kb/925196#fixit4me
http://go.microsoft.com/?linkid=9643528
For the above link, click on the "Fixit" box to install the patch.
Jul 04, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Problems adding files onto the hardrive
This sounds as though the Iomega has got locked somehow.
Do a get info on its desktop icon and have a look at the lock checkbox. Also look at the write permissions while you are there.
May 10, 2009 | Iomega (33654) Limited Edition 500 GB USB...
Iomega
Yes. The MiniMax is designed to match the MacMini from Apple and comes formatted out of the box to work with a Mac. (One of the few drives that is!)
I think Iomega supply various Windows drivers on the CD
Apr 09, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
284 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
