Question about Hamilton Beach Coffee Makers & Espresso Machines
HI! i'm back again the last time you've sent me a washer to put in the tank seal but the problem is not the washer.I did every thing you told me and it still dripping.The problem seems to come from the dispenser were the washer sit.would it be possible to send me the dispenser mecanisim. Thank you for your understanding, Johanne Blanchette
  • 5,660 Answers
Johanne, I'm sorry that some 'wires' seem to have become crossed here.
FixYa is a place where you ask questions about a device, you're having problems with, (Computers, Automobiles, Pickup trucks, SUV's, coffee makers, tools, you name it), and people that have experience in the area try to provide a solution to the problem.
FixYa is not directly connected to any manufacturer, and does not provide warranty work, or parts.
However, I would love a chance at trying to provide a solution, to your problem! If I can't solve it, there are many others who may be able to.
I hope when you have a problem that you will think of us, we like to help!
Posted on Jul 24, 2009
Contaminated fuel
It will not give you any problem. Drive and enjoy.
Mar 22, 2013 | 2007 Honda Civic 2.2i-CTDi
I've a 99 protege replaced the rear main seal in, and leaks again , I was told that the crank was worn and that's what caused it to leak again could this be true or am I getting scamed
unlikley as its only the rubber that touches the crank shaft on any car but it could be warped moving the seal and letting oil out more likeley if its still leaking did the garage do it it may be that the seal was rubbish they put in and are trying to get more money out of you for the sake of another seal was it genuin parts of aftermarket parts as some times that makes a masive difference hope this helps
Sep 24, 2012 | Cars & Trucks
Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Sep 09, 2009 | Eljer Toilet Onepiece Canterbury ...
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
I have a Samsung washing machine which is leaving grey / greasy marks on my clothes? any suggestions? I'm not sure what's causing it. I've tried spinning the drun and it feels a bit rough so not sure if it...
bearings may have gone but the marks on the clothes sounds more like the door seal pull the door seal away from the drum slightly and see if it's dirty you get a grey slime caught in the seal give it a good clean
Jul 13, 2009 | Samsung Washing Machines
Bunn B10-B leaks
I used Foxhollowrun's solution and went to my local hardware store (Menard's). You can purchase 3/4" Hole Grommets typically found in the electrical department. The brand I purchased was Gardner Bender Model GHG-1575 3/4" Hole Grommets. Here is all that you need to do (very quick and easy):
1) Break away the brittle pieces from the original hole in the resevoir.
2) Remove the old rubber / plastic washers - I found I didn't need them. However, hang onto your metal washer that the drain screw goes through.
3) Slip the 3/4" grommet around the hole.
4) Place the original metal washer on top of the grommet.
5) Screw the drain screw back into the heater which will seal the grommet via pressure. Be sure not to over tighten it - I just snugged mine up.
6) Put everything back together, rinse several pots of water through it, check for leaks, and you should be good to go.
As Foxhollowrun indicated, you may need to tighten the drain screw a bit if you do have a leak. I lucked out - it worked the first time. I believe it cost me about $2 to fix. Also, I did not need any caulk. If you do use caulk, I was told you need to use food-grade caulk.
One last note - as Foxhollowrun indicated, the grommets are quick thick which is why I removed all of the old washers. The original metal washer is just thin enough to allow the drain screw to be reinstalled.
Thanks to Foxhollowrun for a great remedy!
Jan 02, 2009 | Bunn B10 Coffee Maker
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
Pioneer SD-P55A3-K Proj TV will only stay on if I run a fan behind it...
Thermal issue !
A component inside the set has a thermal issue !
This may require hours of trouble shooting to find the components responsible.
Once the component(s) are found they could be serviced.
azkeyz@fixya.com
Wizard Division
Sep 23, 2008 | Pioneer Televison & Video
Controls are flashing but nothing happens when you press start
Belt came off! It has happened to me severeral times, however; my father usually puts it back on. Take the screws off above the drawer if you have a pedistal one. Check and see if the tiny little belt is off. Happend to me 3 times in the last 2 years
Jun 03, 2007 | Kenmore Elite 45986 Front Load Washer
New mouse, still has problems
Some mice eat batteries like they are nothing. I myself have a logitec wireless mouse and i must replace the batteries every two weeks. I would suggest getting another mouse.
May 24, 2007 | GE Wireless Optical Mouse
Coffee Makers & Espresso Machines Logo
416 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
