SOURCE: my oven wont come on
try this if one of the dials is pushed in turn the other around till it pops out
SOURCE: HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
SOURCE: Smeg sp9000x.2 double oven - no heat from top oven
hi
the changes are if the fan is turning and light is on then the element around the fan will need replacing hope this helps
regards dan
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
SOURCE: westinghouse oven pof668 in auto
Most models won't work when on Auto. Generally there
are push buttons under the clock and one has a picture of a hand (Like a cop
holding up his hand to say "Stop"). Press this button and it should
go back to manual mode and allow you to use the oven.
What I have said so far is pretty much a guess, based upon experience. I'm also guessing that you don't have a manual to refer to either. However, while I can't find the specific manual for your model, there is a westinghouse oven manual here:
http://manuals.appliancesonline.com.au/westinghouse-dualfuel-ovens/westinghouse_duelfuel_ovens_manual.pdf
and I would bet that the clock setting instructions on page 18 are exactly the same for your appliance!
