Question about kawasaki Quad Bikes
Kawasaki prairie 360 atv spits & sbuters at wide open throttle & when you gas it from a dead stop but runs fine in between i have already cleaned the carburetor any ideas off what could be my trouble would help
Its your choke. when the choke is to the left it will sputter around. try moving the choke completely to the right. mine does the same thing u just have to run the choke on the right side. i dont know if its supposed to be on the left or right but if u push it ALL the way to the right it should be fine. my kawasaki 360 prairie is pushin 55 mph so i think i have it set up right.- Kyle
Posted on Oct 05, 2009
My 1999 Kawasaki prairie kvf 300 runs smooth but will not rev all the way up to full rpms.
Check that the rev governor/throttle cable adjuster screw has not slipped out of adjustment (lock nut vibrated loose).
Apr 05, 2017 | kawasaki 2005 Prairie 360
My 2003 Kawasaki prairie 360 when u install the hose from the air box it will only idle u can not rev it up take the hose off and it runs fine
2003 360 Prairie 4x4 cutting out... I'm stumped! - Kawasaki ...
www.kawasakimotorcycle.org > ... > Kawasaki ATV and Mule
Dec 14, 2011 - This 360 4x4 has me stumped. ... 2003 360 Prairie 4x4 cutting out. ....It idles just fine, it has perfect throttle response, it just won't rev without ... 2006 Prairie 4x4 governor prob?
Oct 1, 2009
04 Prairie 360 Knocking when Idling and Belt Light on.
Jan 26, 2009
Older Prairie Tune Up Questions
Sep 19, 2008
Prairie 360 (Limp Mode)
Jan 4, 2005
More results from www.kawasakimotorcycle.org
Nov 19, 2015 | kawasaki Motorcycles
Will idle & run at slow speeds, bogs down at higher speed.
Prairie 360 revs high but goes slow (45mph) - Kawasaki ATV Forum
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Oct 27, 2008 - 2006 Prairie 360, wife's ride, polar white, with 26" Swamp Lites on SS108's. ... that it has a low top-speed...45mph is about as fast as they seem to go. ....air cooled motor theres no real performance there, the P360 wts are light ... Can't put 2005 Kawasaki KVF 360 into gear
Jun 30, 2013
Prairie 360 speed/power issue?
Aug 28, 2012
06 Prairie 360, too many rpms???
Nov 30, 2011
2004 Prairie 360: WOT miss
Nov 9, 2011
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki 2005 Prairie 360
Will idle & run at slow speeds, but bogs down at higher speeds.
Prairie 300 carb problems - YouTube
? 0:28
www.youtube.com/watch?v=w1-znueTqFE
Dec 3, 2012 - Uploaded by Joey Fortner
Prairie 300 carb problems ... The slide (the piece you see moving up and down) has the needle running .... 2005 Kawasaki PrairieIdle issue.
How to adjust prairie 360 timing
http://www.kawieriders.com/forum/kawasaki-brute-force-prairie-bayou/104945-timing-chain-issues-360-pra.html
May 10, 2014 | kawasaki 2004 Prairie 360 4x4
Why does my 2005 360 prairie idle fine when wet but bogs down when u push down on the throttle?
My brother had the same problem on his prairie 400. He was getting water in the electrical connector for his CDI unit. Unplug all of the electrical connectors one at a time and make sure they are dry. Apply dielectric grease to all the connections and plug them back in. I recommend doing this one at a time so you don't mix them up or forget where they go.
Apr 14, 2014 | kawasaki 2005 Prairie 360
2006 kawasaki prairie 4x4 model kvf 360 c belt indicator light reset
On the right hand side of the ATV just under the gear leaver, you will find a grey and black multiplugs, you will need to swap them. Please see the link below. KAWASAKI 360 PRAIRIE BELT RESET
Sep 23, 2013 | kawasaki 2012 Prairie 360 4x4
Bogs down & spits back through carb.
Sounds like you may need a valve job. Have you been keeping the valve clearances adjusted? It's important to do that on a four-stroke engine. Check your compression to find out if the valves are ok.
Sep 19, 2009 | Polaris ATV
kawasaki Quad Bikes Logo
1,349 people viewed this question
Top kawasaki Toys Experts
 binay biswas
binay biswas
Gregg Mahin
Gregg Mahin
Vernon Taylor
Are you a kawasaki Toy Expert? Answer questions, earn points and help others
