Question about JBL Car Audio & Video
I have a JBL in my toyota highlander 2008 and have just bought an aftermarket head unit that has an amplifier. How do I connect with JBL
  • 2 more comments
  • jntetmen Jul 23, 2009
    well I know that the output from my aftermaket unit should go directly to the speakers. However, if that was the solution I guess I wouldn't have asked you expert. Is there a way I can still use the JBL can I reduce the power level of that amplifier output so that i connect to JBL amp? is there an attenuator for such a configuration?
  • jntetmen Jul 24, 2009
    Hi Welcomee
    I know what you are saying but there is no line out except for the audio output which is high level,
    and when you say i should use line out what do you mean what should that be connected with
    I sent the unit description with all the connections to Fixya they should make it available to you
    regards
    Hi buddy I undersatnd ... have you seen the unit description and connection drawing I sent? it is unfortunate i cannot attached it to this note.
    I basically have on that unit back pane the following:
    - AV input: 3 jacks audio left audio right and video
    - Audio output channels: left front, left back, front right, right back, center, subwoofer
    - digital audio output
    - AV outputs: it has left and right audio input ports as well as 2 video ports AV1 and AV2
    does this help a bit further?
    thanks
  • jntetmen Jul 27, 2009
    Hi the 5 channels are speaker-level output so they can't go into JBL but the AV one may be ...
    I'll try to simulate with a cheaper amp before. What about the digital line-out? I thought JBL had a digital input...do you know anything about digital line-out ?its purpose etc...
    Thanks
  • 10,594 Answers
Check Line Out jacks in head unit that will be connected in JBL amp Input.
Please do not connect head unit amp output with JBL amp input even with minimum volume level that will damage JBL amp input circuit.
Only use Line Out to connect any other amp with head unit.
Thanks.
Posted on Jul 23, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jul 24, 2009
    Hi Welcomee
    regards
    Well, if head unit does not have line out pins then it would not be connected with any other amplifier.
    this note.
    thanks
    I do not see any drawing attachment here and based on specifications, "- AV outputs: it has left and right audio input ports as well as 2 video ports AV1 and AV2" there you can hook JBL amp input to get sound.
    You can email me pictures of head unit rear at welcomejee@yahoo.com
    Thanks.
    Shahid Electronics Jul 27, 2009
    I received CA3637 Quick Guide that has connection details about head set.
    There are 5 channels audio out and 2 channel audio out (stereo) available on head unit to hook with JBL amp, please check Page-9
    Audio out pins are marked in blue in below image that can be hooked with JBL
    Thanks.
  • 784 Answers
Toyota already has amplifier and all speaker wires are connecting to these out puts. With your new unit having an amplifier, all connection from your new unit outputs should be going directly to speakers not going through original amplifier. If you don see the original amp, it may be under the driver seat. Hope this can help.
2008 cd player broken no way to code
2008 Toyota Camry CD Player - Discussion on Topix
www.topix.com > Toyota Camry
Dec 10, 2007 - #1 Dec 10, 2007. Just bought a 2008 Camry LE with standard CD player. ... Toyota will repair the CD player tomorrow morning. I still have a CD stuckthat I can't ... Toyota Highlander Radio Problem
Aug 2, 2010
2009 Corolla Stock Radio Display goes Blank.
Jan 18, 2010
2007 Toyota Camry Radio Reception
Mar 17, 2008
More results from www.topix.com
images for Toyota 2008 cd player broken
Oct 21, 2015 | 2008 Toyota Highlander
Head unitsays amp error
Then you likely have a defective amplifier.
Mar 18, 2014 | 2005 Toyota Camry 2.4
Which is the spare tire indicator on the 2008 toyota highlander?
open glove box, extract the operators guide, its all there.
or if lost buy one, or call toy and beg, they give many away to avoid
lawsuits. (safety)
google for them works 1/2 the time, try google it is your friend
search" 2008 Toyota Highlander operators guide"
Dec 05, 2013 | 2008 Toyota Highlander
My JBL radio #16833 for Toyota Highlander has no power?
The radio has burned out, no other explanation
Feb 02, 2012 | Cars & Trucks
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
I have a jbl gt series gt5 a3011 amp light on top comes on but the power light doesnt fuses are good everything seems to be connected right and no sound to speakers .
Run a jumper between the power wire and the remote (disconnect the remote wire from the head unit first). If the amp turns on, you got a blown fuse, or other problem with the remote turn on from the head unit.
Jun 18, 2011 | JBL Car Audio & Video
I have a 2008 Toyota Highlander with the TO factory option. I installed an aftermarket trailer hitch. Do I just need a trailer light pigtail (to connect to the connector in the rear) or must I also...
I believe the box also is a safety feature in case of a wiring problem from some event, like an accident.
You need a converter to convert the turn signals and brake lights to run off the one bulb on the trailer. A flat 4 pole connector is the usual connection. A 4 to 5 pole converter may also be needed to add the backup light power to disengage the surge brakes while backing up If your trailer has that option. 4 to 5 is not really necessary but it eliminates having to get out and move the connector or insert the brake bypass key.
Aug 14, 2009 | 2008 Toyota Highlander
CAR CD CHANGER - ERROR 3
replace head unit the cost to fix the problem you could but two deck ,use a wiring harness and get the aftermarket mountain kit
Jun 09, 2009 | JBL GTO75.4 Car Audio Amplifier
Crutchfield.com has manuals for your specific car that will show you how to get it out. Otherwise just start popping off dash panels around the radio.
Sep 28, 2008 | Infinity Reference 1211a Car Audio...
Car Audio & Video Logo
125 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
