Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
57F500A, powered light on with no sound/picture, ticking noise
I have a Hitachi projection television, model 57F500A, serial V3K011368
Originally it had a convergence issue with 2 colors not lining up. I replaced the chips and had it working for about an hour when the picture and sound went out even though the red "on" light was still on. I opened it back up to now find a convergence resistor burnt (the RK54 which I examined to think was a Brown/Green/Gold), which I replaced and tried again, but still no picture or sound.
I still have the back off, so what I did notice was of the LEDs that light up (2 green on left, 2 green on back right, 1 red on near to me right) the closest of the back right green LEDs (D940) was blinking in sync with a ticking sound (like a spark but no fuel) and the near right red LED (D915) was dimming in sync with the ticking.
I read one of the responses here that it could be a fuse issue, there are two 5A 125V, and one 6A 125V. Is this the problem? If so I've called local stores about their fuse availability and I can get 5A in a 250V form, which I'd not prefer due to the point of the fuse. The other can come in a 6.25A slow blow, which I'm not sure what the TV requires.
Any suggestions would be appreciated.
  • bb31ee Jul 26, 2009
    The thing is, the resistor hasn't blown again, and what explains the ticking and LED flashes?
    I've replaced the 3 Fuses and there was no change.
  • 668 Answers
Over the years of servicing these sets and others for Convergence issues, I have on several times gotten defective Convergence ICs. In your case where a Resistor is now open, (Probably a 1.5 ohm 1/2 watt), I would suspect you had gotten a hold of a defective IC. I would replace them both again. Make sure to use Heat Sink Compound between the ICs and Heat Sink.(Just a thin coating on the metal area) You can get the heat sink compound from Radio Shack. They should also have the Resistor you need.
Good luck,
Skyassoc
Posted on Jul 25, 2009
  • Steve Yocum Jul 27, 2009
    I do not think that it is a open fuse. It it was, one of the LEDs would not light at all. If you have blinking LEDs that go in cadence with the ticking sound I would check the Horizontal Output Transistor, and the HV Output Transistor with a OHM METER and see if one is shorted. These would also be attached to their own heat sinks. One would be near the High Voltage Transformer and the other would be left center on the Deflection Board. If they are ok I would unsolder the new Convergence ICs. Then turn it on to see if the set runs. If it runs, replace the ICs again as a pair. It may not burn the resistor at this point because the set is going into a protect mode that will not allow it to go to full power up. I wish I had a dime for every new defective Convergence IC I have seen. Especially a STK392-110.
What's the value of resistor RK42 on the Hitachi 57F500A?
3.3 ohm/ 1 watt / metal oxide. HIT p/n: AT03202S -- red hor. conv. -- from IC ik04 (STK392-110/150)
May 03, 2010 | Hitachi 57F500 57" Rear Projection...
Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
Mar 28, 2010 | Hitachi Televison & Video
Hitachi Projection TV 57F500A red looks double.
You need to replace both of the convergence IC's and any bad resistors around them that protect them from damaging the power supply.
This repair can usually be done in the home and takes about an hour; I have done hundreds of them and now is a slow time of year for TV shops; look around if you are not able to do this repair; you can buy the chips on Ebay for less than 15 dollars for a pair plus shipping.
This is a very common problem in projection sets.
If this has helped you give me a vote here as I do this for free. If you have questions or need help:
etower.766@netzero.net
Aug 23, 2009 | Hitachi 57F500 57" Rear Projection...
On my Hitachi 57F500A the red looks doubled. I
This is usually cause by bad convergence IC's with part# STK392-110. There are two that need to be replaced.
Aug 20, 2009 | Hitachi 57F500 57" Rear Projection...
My hitachi 57f500a picture went out and sound. When you power up you can hear the clicks and the red light in front comes on solid. Out of the five leds on the power board four of them are on when...
There should be a solder in pico fuse(yellow) close to that LED labled E...something. It is most likely open. If so, check to see if there is a blue high voltage capacitor(2kv) in front of the H.output transistor. If yes, replace them both...if no try just replacing the pico fuse.
Jul 07, 2009 | Televison & Video
Power but no picture
I doubt it is the picture tube...there are three of them.. a red. a green, and a blue. Would suspect something on the power/deflection board
Jul 05, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 43F300
BAD STKs YOU have 2 of them replace them both 392-110s up grade 180s.
Sep 10, 2008 | Hitachi 43F300 43" Rear Projection...
HITACHI TV MODEL 57F500A
My hitachi 57f500a wont turn on i pulled the back off and there are only one green light on and the relay keeps clicking when the relay clicks another green light flickers and the red one come on and goes off.
May 04, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
422 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
