Can only select channel 13 no other numbers respond. Channel selector only goes down, won't go up, volume control will only get lowers, will not always go down. Power switch does not respong. Have already gently cleaned unit put in fresh batteries
    Novelist:
  • 133 Answers
Did you use your remote a lot?
Do some buttons work sometimes if you press them really hard?
If it's a double yes and you've already cleaned the remote (the rubber pad with buttons and the circuit board with contact tabs), then the buttons are most probably worn out, which means they no longer make a good contact on the circuit board tabs.
There's a repair liquid kit for remotes, i'm not sure what the brand name is or where to get it, in europe, conrad electronic was selling it some time ago, however, i make my own from benzene, rubber glue and grapphite powder.
The other solution is either to find a new rubber button pad or to get a brand new remote...
regards
3rq8 (Triarcuate)
Posted on Jul 26, 2009
How do I get the menu cursor to move up or down in order to rescan my TV?
either the channel or volume buttons perhaps if there are no other up,down buttons
Nov 17, 2015 | Televison & Video
Tip
How to set your clock radio
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control, or both, Volume for "Hour" and channel control for "Minutes". Check which control lets the selector jump from "hour" to "minute and set the minutes. To exit settings menu, depress "clock" button again
on Dec 02, 2009 | Car Audio & Video
How do I turn the Closed Captioning on?
Try and hold both volume up channel up at the same time for at least 5 seconds and hope that the menu will come up. Use the channel arrows to select your choices. If that doesn't work, try channel down volume down as your combo.
Aug 31, 2013 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
How do you change the channel on this model?
Hi Eric,
Does the unit have knobs on the top of the unit, or just buttons in the front panel beneath the screen?
If the former is the case, one of them will have numbers on it, this is the channel selector.
If the latter is the case, then you should see two buttons with up and down arrows on them, one is Volume, the other is Channel selector.
I hope this is useful to you.
Cheers,
Peter
Dec 19, 2012 | Motorola AXU4100 (10 Channels) 2-Way Radio
Repeats selection and won't chage seletion. superstar 3600
Obviously your channel display must be working. I would assume the radio has sustain some harsh trauma to the channel selector itself possibly a drop.
Remove the speaker side cover looking down on the channel selector and its pcb board check connection and between the mechanical switch and pcb.
This may be as simple as a cold solder joint the problem is finding it.
http://www.cbtricks.com/radios/superstar/3900/graphics/ss3900_sch.gif the schematic is for the 3900 which i believe are similar units.
Oct 24, 2011 | Radio Communications
I just hooked up cable and dont have a remote for my older tv how do I get to ch 3??
Good day,
Look on the back of the tv to see if you have a channel 3 4 selector.
If so, set it to 3.
If your tv has basic controls on the front, such as on/off, volume and channel select, remove your cable hookup to the tv, turn on the set, and using the channel controls set it to channel 3.
Reconnect.
Feb 08, 2010 | Zenith Z25A11S 25" TV
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
Catv
try to purchase a new remote for samsung because all samsung remote is universal to all remote units.and there you can set the program.
Sep 04, 2007 | Samsung TV Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
