Question about Philips GoGear SA3125/37 MP3 Player
All songs wont go on,then memory gets corrupted
When i put songs on my philips gogear sa 3125 it turns off after at leats 56 songs, and then when i plug it out it says memory corrupted and there is no space on it
  • 34 Answers
I think the flash memory is defective. if you have still warranty on your device bring it to your dealer. if not, you could try to format the players memory. go to my computer, right click on the device and use the option format. data format should be fat32. you do this on your own risk.
Posted on Jul 23, 2009
Philips gogear sa145/02 4gb when i turn it on get message memory corruption repair now
go to magnovox.com and dowload root software delete all files on the gogear the add software to the root menu in the gogear this will reset it to default you will loose your songs but fix the problem
Apr 17, 2009 | Philips Audio Players & Recorders
Downloaded songs but won't play on go gear 3020/37 how do i fix
First try opening the gogear device and click on music right after the welcome screen. Select either "All Songs", "Artists" or "Albums" to find your songs. If you downloaded your songs, they should display on the screen of philips gogear, then you can select them to play on your headphones
Only some audio formats (.mp3 .wav and .wma will be play on philips gogear SA 3020/37)
Feb 23, 2009 | Philips GoGear SA3020/37 MP3 Player
Philips gogear SA 13 56/97... i want to format it.. plz help
www.p4c.philips.com
Select country / language options then search on your model number. This site has manuals & drivers for all Philips products.
Feb 04, 2009 | Philips Audio Players & Recorders
My philips gogear format problem
there is a reset point in the gog gear..reset it and get all your songs in again
Jan 28, 2009 | Philips GoGear SA178 MP3 Player
How to format philips gogear mp3 player?
I wouldn't format it. If you are having problems, run a Repair in Philips Device Manager. If you are getting format errors, then the songs you are trying to load are not compatible with the player - if you download songs that are in true mp3 format, then you will not get any format errors.
-Tha Mp3 Doctor
Jan 25, 2009 | Philips GoGear SA3125/37 MP3 Player
How can i download songs onto my GoGear mp3 without that disc thingy?
Get the software from www.usasupport.philips.com - Use Windows Media Player to transfer and delte songs from your player. Older GoGear's (HDD models) require Windows Media Player 10. Most SA models are fine with Windows Media Player 11.
Jan 03, 2009 | Philips GOGEAR SA6045 MP3 Player
Can't turn off
You have to hold the button in for about 5-7 seconds, and then it will say "Bye" and shut off normally.  If it won't shut off because it has frozem, then reset the device. If it continues to freeze, run a "Repair" in the Philips Device Manager: Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Sep 13, 2008 | Philips GoGear SA3125/37 MP3 Player
Please help
Try to hold down the power button while pushing the volume button up at the same time. This resets the device. It should help
Jun 02, 2008 | Philips GoGear HDD6330 MP3 Player
Gogear
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
You must do a firmware upgrade to resolve this issue.
Open Philips Device Manager (Go to Start--> all Programs--> Philips...), and click on Update tab
OR
You can get it from www.usasupport.philips.com
It will delete all songs off your player, so be forewarned
Enter your model number on the website, click the link on next page that says SA 5125/37 w/o a "b" on the end
Click on Software and drivers tab
Click on firmware upgrade software - instructions enclosed
-Tha Mp3 Doctor
Mar 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3125/37 MP3 Player Logo
109 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
