Question about Canon PIXMA MP760 All-In-One InkJet Printer
Can not photocopy
I can not photocopy from an original. All cleaning of machine has been done and all ink is full. What could my problem be? and how can I fix this?
Thanks
  • spjost Jul 24, 2009
    I am trying just to photocopy with the printer. So basically I have placed my information on the clear glass top and press copy, then press black and white and nothing copies.
    I have also tried the same process with pressing copy, then the color, this works better however the copy is still grainy and the colour is not totally accurate.
    I have copied from this printer in the past and have had no problems.
    Thanks for the help
  • aa1Consult May 11, 2010
    What application are you using to scan?
  • 164 Answers
Once scanned a document needs to be save din a file format that the PC can read..doc docx..pdf..txt..go into Word or whichever word processing app you use and click import, from TWAIN device
Posted on Jul 24, 2009
INK PADS FULL
get the ink reset utility with key
May 02, 2013 | Epson L200 Original Continuous Ink Tank...
When copying by putting the original thru the machine, half the copy come out solid black. Putting it on the glass under the lid the copy comes out perfect. Any ideas why this is happening? How can I...
A user default
1.The printer is possibly not designed to perform in color copying through the machine feeder area, only on the photograhic image scan area. Discontinue scanning the image in feed area.
A Technical default
1. The device is nearly out of ink
2. The device printing bands are clogged requires cleaning
A printing material defect
1. The positioning of the medium to be photocopied only achieves success when layed flat on the screen. Possible images are likely when lightening does not escpe in the process.
Consider, using an alternative copy machine that would achieve success.
contact technical expert, soon as possible
Dec 01, 2010 | Canon LaserCLASS 510 Printer
I rifil canon Fax -JX 201. 1st time It Good worked. But 2nd Refill icant get photocopy; But it say "No ink" .How to Reset that error
by refilling the ink crg. you probably destroy head electronics. Buy new one ORIGINAL, and try then.If you must refill ink be carefull, rather buy new reffiled ink, where the chip is resetted.
Hope that helps!
Aug 10, 2010 | Canon FAX-JX200
I only want to use the black ink, not all 4 colors
Color printer have sofware installed which stops all printing inless their is ink in all containers. No, their is no way around it. Someone would be rich making a kit to do so. since I see this question over and over  at least once a week.
Mar 09, 2009 | Brother MFC 420CN All-In-One InkJet...
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The ink absorber is full and printer won't print.
Normally when you get the "ink absorber is full" message, you would take machine to a Canon service center. They will either clean the ink absorbers or more than likely they will replace the ink absorbers. After replacement, the ink absorber full message will have to be reset which is done in the service mode.
Inkworks
866-381-0541
Nov 21, 2008 | Canon PIXMA iP1600 Printer
Brother MFC5840 CN Print heads
I guess you have used generic ink carts.
You should buy an original brother ink cart.
When done so make sure all other carts are at full level:
Press menu then start b/k copy then fourtimes arrow up (tel.index). Machine will be in maintenance mode. press 7 then 6 then 4 then start b/k copy. Machine will refresh ink within tubes and print head and do some power cleaning. when finished press 7 then 6 then 3 then start bk copy to run an extra power purge.
Leave maintenance by pressing 9 then 9.
Do run a quality test print.
If you re lucky the it will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintenance mode.
If you like to save money refill ORIGINAL Carts by drilling a 2mm hole into the top (O of brother brandname) . You can leave the hole open to refill the cart next time directly without taking it out of the printer.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of distilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
For bk mix 1 ml glycerin alc with 4ml dest. water and 15 ml bk DYE ink (shake well before refill).
This is -nearly- the exact mixture of original brother ink.
Mar 12, 2008 | Office Equipment & Supplies
Stuts,
If you re lucky the ph will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintnenace mode.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of destilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
This is -nearly- the exacte mixture of original brother ink.
Mar 02, 2008 | Brother MFC-5840CN All-In-One InkJet...
Photocopies - Canon Imageclass MF3110
replace the cartridge, the drum cleaning blade is failing
Dec 20, 2007 | Office Equipment & Supplies
Some colours not printing
I bet you are using non genuine ink, the MP780 will not put up with that ink, you will need a new printhead and maybe a purge unit. Take the machine to your ink supplier and get him to fix it as he supplied the ink
Jan 29, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
67 people viewed this question
old marine
old marine
