Ac unit does not turn on
My tempstar unit makes a clicking noise but wont turn on does anybody have a solution to this problem???
  • nathanmendoz Jul 23, 2009
    what can be done about this because
    if i push on it and hold it it makes a fluttering noise but still doesnt turn on!!!
  • Ken Bledsoe May 11, 2010
    Sounds like a contactor not fully engaging. Go Outside and open the electrical panel to the unit and look at the part. See if it is locking in or just fluttering.
  • 306 Answers
If you have to physically hold it in? Then your coil is bad on the contactor. Need new one. You need to test the compressor ohm it out make sure it is still good. Check your capacitor also. It starts to get a little involved so if you are not real comfortable with this might have to call in a tech. But if you need some help just ask can walk you through this step by step.
Posted on Jul 27, 2009
    Sergeant:
  • 202 Answers
The freon pressure might be low or too high, maybe thats why it doesn't turn on.
Posted on Jul 23, 2009
Just installed a used tempstar nulk075dg03 turned on power and the blower fan wont shut off. turn the thermastat asking for heat the blower motor goes off and the glow comes on the fire lights for a c
its wired up wrong somewhere try to bypass the thermostat wires at the unit and confirm the unit works
then youll know more
other than this i would consult the installation guide and user manual first ...!!! get them from the makers site some makers manuals are not on the general google type search but readily available from the makers site
Dec 21, 2014 | Fasco Intercity Heil / Tempstar Furnace...
Dometic Duo Therm RV AC makes clicking noise when turned off
The braker is getting weak and needs to be replaced the act should be cleaned as the coils get dirty and make the units work harder
Jul 19, 2014 | Dometic Heating & Cooling
Loud humming noise from under my Tahoe 2 WD
Is it closer to the back of the vehicle or the front?Possibly the fuel pump. Try opening the gas tank and stick your ear close to the intake of the tank while someone turns the key.
Aug 02, 2012 | Chevrolet Tahoe Cars & Trucks
2003 ford expedition rear ac makes noise when engine running and how to remove the cover of the same
What kind of noise is it? If it is a "clicking" noise, a common problem on the Expy, you will need to replace the Blend Door Actuator. This is a small unit on the passenger side, rear. When you take the panel off, turn the key on to make the noise so you can locate it (there are actually 2 units) they have plastic gears that strip out, making the clicking noise. To remove the panel to access, you'll have to carefully pop the panel off and remove a couple of bolts around the seatbelt.
Jan 28, 2011 | 2000 Ford Expedition
Tempstar a/c condenser screeching noise
Could be the fan motor's bearings. Try turning the fan by hand to see if spins freely or is tight. If it's tight you can try oiling it but that may not work for long.
May 30, 2010 | Heating & Cooling
Tempstar phad42n1k1 heaters come on in ac mode and compresor or fan wont run in heat mode. was able to make heatpump go in defrost mode and compressor runs.
sounds like u have the thermostat wired wrong or bad wires i would check that first make sure you have the wright thermostat
Jan 05, 2010 | Ruud Central System Air Conditioner
Need info. on a Tempstar Comfort 2000 unit.
This is a 2 speed condenser fan control board, the tempstar part number is
1086071, if you google tempstar 1086071 you will receive 1 listing for the part for something like 44 bucks, but if you go to sears parts direct and enter the part number they have a factory authorized substitute part number 1088977 that you can order from them for $17.49, some tempstar units were shipped without this control unit and the 2 speed fan just runs off the contactor on high speed only to do that disconnect the control unit and connect the black and orange wires that ran from contactor to the control unit previously together, and then the fan should come on in high speed when the condenser is on. there is a kit that they shipped these control units http://icpindexing.mqgroup.com/documents/086477/48201222001.pdf, (just for you to look at) so all you really need to do is get the new part from sears or run the motor in high and get rid of the part all together, hope this helps.
May 30, 2009 | Heating & Cooling
I have a tempstar 2000 heat pump approx 5 years old. The condenser fan blades will not rotate/operate; however, I can hear the motor hummming. When the unit is off, I can rotate the fan freely. When the...
I think this is a double problem post,so I will answer the top first.
The fan capacitor may be bad or the motor it's self is seizing up and will need replaced.
Second portion of post:
  1. Brown and brown/white go to the new capacitor(If you didn't get a new one with the motor,You will need to)Should be 7.5 mfd
  2. Black To the contactor where the black was originally connected
  3. yellow to the contactor where the red was originally connected
May 06, 2009 | Heating & Cooling
Makes loud noise when first turned on
It may have been damaged in shipping or from the manufacturer. I would consider exchanging it for a new one.
Jun 15, 2008 | Danby Portable Air Conditioner
Heating & Cooling Logo
240 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
