I need to get into a Lucent Clear trac to change IP addressing and such. I would like to throw the damn things away and start new but noooooooo!!! I need to find a manual for this or at least find out some defaults so I can get into the darn thing to figure it out can you help??
  • ckelldo Jul 25, 2009
    Hey Thank you Doug,
    It is the V 410 Cleartrac from Lucent. Was manufactured in late 90s to 2001 before being discontinued. It is used as an earlier voice of frame relay interface to connect 2 PBX systems together. It uses a telnet interface and does have a serial port on it but I cant get it to bring up anything when connecting to the serial and doing a power cycle. I was hoping someone out there might have some experience with one or better yet a manual for it. Thank you for taking the time.
    Chris
  • Douglessd
    Douglessd May 11, 2010
    The following page has a stack of router usernames and passwords.http://www.irintech.com/x1/blogarchive.p... What is the Model Number of your equipment? Have you done a factory reset on it? Do you know if it has a HTTP interface or a Telnet Interface? I don't suppose it has a serial interface for administration? Good Luck. Post more info and I'll help you search. Doug
  • 284 Answers
Hi Chris, I found this on ebay. http://cgi.ebay.com.au/LUCENT-ACT-NETWORKS-CLEARTRAC-V410-SDM-9400-UAC_W0QQitemZ360173434662QQcmdZViewItemQQptZCOMP_EN_Hubs?hash=item53dc027726&_trksid=p3286.m63.l1177&_trkparms=|293%3A1|294%3A50 . It's a bit of a long shot but maybe that guy has the manual or knows the password. I assume this is for your office and not something you are doing for fun at home. Perhaps you can get your boss to buy a second hand one that comes with a manual. They don't look very expensive.
Posted on Jul 25, 2009
How to convert to access point
I assume you're talking about using a wireless router as an access point. First, you need to run a wire from on of the LAN ports the new wireless router to one of the LAN ports of the new wireless router. (The back of your router has one Internet/WAN port (often yellow or blue) and several LAN ports.) The simplest way is to use a Cat5 or Cat6 patch cable, which you can buy in any length from 1 to 300 feet. (It's possible you'll need a crossover cable, but I haven't needed one of those in years.) If you're thinking of putting them in different parts of the house, and you can't run a cable between them, then you probably can't do this. (There are devices that are capable of creating a wireless bridge, but you'd need both devices to share that capability, and it's not typical on home devices.) You could try getting a pair of devices that use your house's electrical wiring (like these http://us.dlink.com/product-category/home-solutions/connect/powerline/), but that's not always successful (you need both outlets on the same circuit, for one thing).
Second, you need to change the configuration on the old router/new access point. That box is doing a lot of things that you don't need it to do any more, but I don't bother disabling them, except for one thing: DHCP. Wireless routers are generally configured to hand out IP (network) addresses to other devices on the network (your computers, DVRs, game consoles, etc.). If you have two devices (your new wireless router and the access point you're creating) handing out network addresses, it can get messy. So you need to log into the old router and disable DHCP (which some manufacturers call "assign network addressing" or "IP address distribution" or something like that).
One other step you may need to take is to change the IP address of the new access point. Still logged into the router, find where the LAN (local) IP address is set, and change it if you can. There are 2 reasons this can be important.
1) If your access point and your new wireless router both have the same IP address, you'll get lots of problems.
2) If your access point and your new wireless router are not on the same subnet, you'll only be able to login to the access point through a wired connection (and even then you may have to change your computer's IP address to match the access point's subnet.)
You can change the access point's address to anything you want, but you need to make sure of 2 things:
1) No other device has that IP address.The easiest way to ensure this is to make the last number in the address 253. That address almost never gets used.
2) It's on the same subnet as your new wireless router. I won't get into subnetting; what you need to know for your home network is that devices on the network can only communicate with other devices whose address starts the same way. For all the home routers I've seen, it's either 192.168.0 or 192.168.1. So you need to log into your new router and see if it has the address 192.168.0.1 or 192.168.1.1 (or you could open a command window on your computer and give it an "ipconfig" command, which would show you your computer's IP address, which will have the same 3 numbers). Then login to the access point and give it the IP address 192.168.0.253 or 192.168.1.253.
In a nutshell, make sure the first 3 numbers match all the other devices on the network, and that the last number does not match any device on the network.
Feb 23, 2016 | Computers & Internet
How i can change ip address of tp link 5210g throw ethernet cable
ok , need to assign your computer a Static IP address within the same
range as the AP's IP address, ip address of AP is : 192.168.1.254
the ip address for pc such: 192.168.1.253, then open your browser and write the ip address of your AP then you will be inside it .
Jan 10, 2014 | TP-LINK TPLink TLWA5210G 24GHz High Power...
There was a problem accessing your account. Please try again in a moment. Error #1
1. Clear your cookies and temporary internet files (AKA cache), exit from the browser, then restart the browser.
2. If you are a home user and do not pay for a static IP address, get a different dynamic IP address; do
[Start] > [Run] > cmd > ipconfig
{{write down the IP address, then disconnect from the Internet with}}
ipconfig /release
{{wait a few minutes and then reconnect with}}
ipconfig / renew
{{compare the new IP address to the old to make sure your IP address changed, then try again}}
If you are an office user, try someone else's PC which will have a different IP address.
Jan 27, 2011 | Yahoo Mail
Sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
Mar 11, 2009 | Sharp AR-M237 Digital Copier
IP Address
To check your IP you need to Go To Start Rum and type cmd and enter
You will find a DOS screen poped up . you need to type Ipconfig . It list you your IP. You need to have a local admin to change your IP
Dec 20, 2008 | Computers & Internet
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
Crack password for lucent DSLpipe
Rather then trying to hack the password, you are probably better off just resetting the router back to factory defaults, and starting fresh. You did say you had to reset the connection IP and speed.
Your second choice is to replace the router.
Jun 19, 2008 | Lucent DSLPipe Bridge/Router
How to reset lucent cellpipe 20 series ADSL router
if you are having problems check online to see what the default after reseting is it might be either 192.168.0.1 , 192.168.1.1 , or 192.168.2.1 get your pc;s ip address in that range then use a ip scanner to scan all computers in that portion of the ip range
May 28, 2008 | Computers & Internet
Cant find my Router ip to do Port forwarding
click on start and click on run
on run open box type in cmd and hit enter
black window will open, type in ipconfig then click on enter then look for the default gateway address, that;s the ip of your router
dont 4get to rate solution
Apr 09, 2008 | Lucent DSLPipe Bridge/Router
Need portal to Lucent rounter in order to configure PPTP
What model Lucent router is it? If it's an older one (DSLPipe, for example) it won't be able to handle the PPTP connections due to a hardware issue. If that's the case, the best solution would be to request that your ISP (if they supplied it) disable NAT on that router and assign you a block of public IP addresses. That way the router will just directly pass on the traffic to your IP address and VPN would work just fine. Regarding a phone number, Lucent was merged with Alcatel in April of 2006, so you may need to contact them. Their contact numbers can be found here: http://www.alcatel-lucent.com/wps/portal/ContactUs
Sep 14, 2007 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
