I have a Model GLTF 2940 ESO Frigidaire front load washer that has been giving me an E 10 error code. None of the possibilitied listed on the Error Code chart seen to apply. I can fool it by using the Delicate or Heavy load programs - once, Then it does it again. I've been putting it on Rinse/Spin to finish off the load.
  • leeway_1 Jul 24, 2009
    we disconnected the hoses from the hot and cold inlets. The cold is heavily corroded - husband says to tell you we're on well water. Can the inlet screen be removed to clean it? How?
    to be continued........
  • 6,784 Answers
HI, this is the result of a faulty water valve or valve wire connection(Cold side). Check the connections to the inlet water valve assembly. Make sure the wire connections that run to the valve are clamped or connected tightly and not loose. if the wires to the valve are connected properly, this will confirm a inlet valve issue. replace it asap in this case.
Most cases, this will simply be a loose connecting clamp on the inlet valve assembly.
Posted on Jul 23, 2009
  • Michael Masters
    Michael Masters Jul 24, 2009
    Inspect the filter screens on
    both the hoses and the inlet valve for debris build up in this case. If you find any debris, clean it out.You can use a tooth brush to clean. Use caution
    to avoid damaging the filter screens because the screens in the
    valve are not replaceable. Due to the well water issue, this may have been the result of a high mineral count tin your water supply. most well water will have a high mineral count. this will clog the inlet screens overtime, causing this error code.
    If the screens cannot be cleaned, replace the water inlet valve. remember to clean the new valve frequently to prevent mineral build up in the future. CRL is very good as well at dissolving mineral build up and calcification as well.
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Error codes on a front load washer
Hello friend, thanks for your post!
From my understanding you would like a list of error codes that apply to your Frigidaire washer. Is there a specific error code you are searching for? I was unable to locate a list of all the codes that would be available within your washer, ATF7000E. With additional information I would be able to assist you further. -Matt
Feb 14, 2015 | Frigidaire Affinity ATF7000E Front Load...
I need a chart showing the error codes for a front load fridgedair washer model LTF2140ES3
Hi Richard....Google - Frigidaire front load washer error codes.
There are several links with code listings. Try the Sears Parts
Direct link.
Regards,
Dennis
Oct 10, 2014 | Cars & Trucks
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Oct 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
