Question about Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 6 series model 110. stopped spining. I have pushed in the lid switch and I hear noise like it wants to work but it doesn't.
  • 6,784 Answers
Test the Lid switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating.
Posted on Jul 23, 2009
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
I have a Kenmore washing machine: Model 110 20722990. When it gets to the final spin cycle sometimes it works sometimes it doesn't. You can hear it going but the agitator is not moving and it does...
ok first, i need you to do a little test,,,put unit on final spin ,does it spin at this time ,,yes so pick the lid up every so lightly ,,did it stop ...put the unit in final spin again unit does not spin push down on unit lid and it spins..in both cases you have a bad lid switch.,,the part # is 3949238 the picture is how it look,,if you need help installing just repost...good luckonthejob5130_1.png
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
I have a kenmore 80 series and its not spinning out the water.
does it drain out the water and spin but the clothes are still wet or is it not draining or spinning?set the timer to spin,open the lid and stick a screw driver into the lid switch hole and see if it spins and drains,also if it doesn't push down and let the switch up,or close the lid down and open it a little do this a few times,you should hear the switch make a clicking sound,if it doesn't click you have a bad lid switch.if the machine is draining and spinning but the clothes are wet,do the same thing with the lid switch and watch it spin with the lid open,is it spinning fast,if not you have a bad transmission and it's not spinning fast enough to remove the water out of the clothes or you could have a kink in the drain hose or something in the pump and it's not draining all the way.let me know what you find and send the model number off of the washer,the number should start with like 110.
Apr 14, 2011 | Kenmore Washing Machines
My 14 year old kenmore 80 series top load ultra care washing machine suddenly stopped draining & Spinning. The troubleshotting guide suggested the drain hose was blocked but we tested it an it still...
set the timer on spin,open the lid and with a screw driver push down on the lid switch,sounds like the lid switch is broke,if it doesn't spin when you push down on the switch then push down and up down and up with the screw driver or open and close the lid,you should hear a clicking sound,no click bad lid switch.send the model number,it's on the back wall where you put the clothes in right under the lid when the lid is open,follow the lid to the bottom and look right under it and you'll see a number that will start with 110.send it and i can tell you what switch goes in that machine.
Apr 13, 2011 | Kenmore Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 110 Series 90 stops at the rinse cycle full of water
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. hence, the reason why you can get it to work sometimes by lifting and closing the lid. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: For future reference, it is strongly recommended that you do not slam the washer lid or place heavy objects on the lid. This can cause damage to the lid switch.
Aug 18, 2008 | Kenmore 15944 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
188 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
