Question about GE GTS22KBP Top Freezer Refrigerator
My GE refrigerator collects water under the crisper and then spills onto the floor..What is the solution?
  • GE Master
  • 4,654 Answers
This is a common problem when the defrost condensate drain becomes blocked. Below is a link that tell more about what is happening. Sea Breeze
- This is when it leaks into the fresh food section.
http://appliancejunk.com/forums/index.php?topic=22.0 - And this link is when it's cause in the freezer section.
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Posted on Jul 25, 2009
  • John Tripp
    John Tripp Jul 25, 2009
    If you need any additional help feel free to let me know, Thanks, Sea Breeze
Water appearing on glass above crispers and onto the floor under the crispers. Happens only occasionally. No obvious source of leak. Back of fridge wall not wet.
Do you have a cooling plate at the rear or the fridge with a narrow tray at the bottom to collect the defrost water? Check the drain hole for obstruction.
Apr 08, 2016 | Refrigerators
I have a 2002 GE Arctica (PSS25NGMDWW) side-by-side refrigerator and recently has started pooling up water underneath the crisper drawer.
check the drain on the refrigerator side also you may have to disconnect to open the panel and clear with hot water or a heat gun.
Dec 19, 2014 | GE Refrigerators
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
GE Profile PFSS6PKXCSS leaks under crisper
i have a ge thats doing the same thing ine has a live running on back dont know if i unhook on back or tahe off control box hey go 2 http://www.partselect.com/ they have diagras and a help solution page let e know when u find solution
Dec 29, 2012 | GE Refrigerators
GE frdge model ctx21eazhrww has water accumulating under lower crisper drawers and spilling onto floor
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 20, 2009 | Refrigerators
Teacuptess my GE top freezer Refrigerator has water under Crisper
Could be but more than likely the drain is clogged. Open fridge door look at the top back to see if you can see water running down back of liner.
Jun 06, 2009 | Refrigerators
GE tFX26KR side by side leaks water onto floor
remove the back of the unit at the bottom where the compressor is, it is held in place with 5/16ths screws. locaate the drain tube going to the drain pan, it is held in place with a spring type clamp, remove the drain tube and run water through it till it is clean and not obstructed, reinstall all parts
Apr 11, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
GE GTS22KBP Top Freezer Refrigerator Logo
396 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
