Question about Acer Aspire One AOA110-1588 Notebook
Can not reload windows vista in Accer pc
Hvae tried four times to reload the disks sent with one sheet of instructions and it will not finish
  • 74 Answers
Try looking into your hard drive to see whats the matter go to the setup menu and look at everything correctly try the disk again and it might work properly
Posted on Jul 23, 2009
Factory reset acer aspire 5315 gone wrong
I think you need to reload windows with a operating system disk. Most times the Factory Recovery discs don't work.
Get a windows operating system disk and just reload windows. The disk must match the Certificate of Authentication (COA) sticker on the bottom of her laptop. In other words, don't use a Windows XP Home operating system disk if the COA sticker says Windows XP Professional or you'll never be able to activate windows.
May 06, 2012 | Acer Aspire 5315 Notebook
I'm trying to burn a music CD on my new HP computer and can't get the source disk to download to my hard drive. I'm an old dude and did print out the HP instruction sheet-still confused.
Hello rhughes612,
You may try burn by CD to CD burn but if you want to select files that you want to burn, you have to ripped the music from the Music CD by using Window Media Player 10 or higher. Or try using software that ripped music from CD.
This is the instruction of CD to CD:
1. Insert the source disk
2. Then hit burn or copy to CD on your HP CD & DVD burner software or application.
Then it will be temporarily copied to the hard drive.
3. after it finishes copying the source disk, you will be ask to insert a blank CD then hit continue or OK
Please reply or respond if this doesn't work so that I could provide you another solution and I'll get back to you as soon as possible.
Sep 22, 2011 | HP Computers & Internet
Paper not feeding properly
Follow these steps to reload paper:
  1. Remove the paper and make sure it's not curled or wrinkled.
  2. Fan the stack to make sure the sheets are separated.
  3. Open the paper support and pull up the extension.
  4. Extend the output tray.
  5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
  6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
    You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
  7. Slide the edge guide to the edge of the paper, but not too tightly.
    Follow these guidelines when loading paper:
    • Do not load paper above the arrow on the edge guide.
    • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
    • If you're printing on both sides of the paper, try loading fewer sheets.
    • If it's wrinkled when it ejects, the paper may be damp or too thin.
    • Do not load paper with holes punched in it for insertion in a binder.
    • Load the printable side face-up. It's often brighter or whiter than the other side.
    • Load letterhead or preprinted paper top edge first.
    • If you experience paper feeding problems, try loading fewer sheets.
    • If you're using special paper, check the package for special loading instructions.
Follow these steps to reload paper in the Automatic Document Feeder:
  2. Tap the originals on a flat surface to even the edges.
  3. Move the edge guides outward.
  4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
  5. Slide the edge guides against the originals.
Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
Driver installation progam says "print head needs alignment" but doesn't say how to do it.
Canon i860
Align printhead automatically:
1) Be sure that the printer is powered on and letter size plain white paper is loaded in the sheet feeder
2) Press and hold the <Resume/Cancel> button, and release it when the Power lamp blinks four times.
The alignment pattern sheet should now be printed out. Wait for the pattern sheet to finish printing.
The printer should stop prompting you for this procedure.
Feb 27, 2010 | Canon i860 InkJet Photo Printer
Restore acer to factory default
If you do not have a disk which comes with some computers, here is what you can do→
This is called a "system recovery"
My windows XP, was already loaded on my computer, when I bought it. These instructions, will clean everything off of your hard drive, so you must back up anything that you want to save. I have done this three times, and I got these instructions, from a computer tech. When starting your computer, tap the F-10 key. click on next-yes-and follow the instructions, that come up on your screen. When you are finished, your computer, will look just like it did, when you first bought it. Do these steps, in order, when finished.
1. set up windows firewall
2. windows update (click express)
3. install your anti-virus program (update)
4. install anti-spyware (update)
5. Install service pack 2..3..Good Luck..
All your drivers etc. will reload on your computer, without a disk. All this information is stored on a hidden partition on your hard drive.. Good Luck
Apr 04, 2009 | Computers & Internet
BROTHER "MFC-3820-CN" TROUBLESHOOTING
You need a new print head.
You could try cleaning the one on there, but all brothers similar to yours are plagued by this problem.
To clean it try:
SWITCH MACHINE ON WHILST HOLDING DOWN MENU/SET KEY, THIS PUTS MACHINE INTO FACTORY SETTINGS MODE.
(MAINTENANCE WILL SHOW ON LCD)
ENTER CODE:84 & WAIT WHILE MACHINE PERFORMS A FORCED CLEANING CYCLE.
(cLEANING WILL SHOW ON DISPLAY)
NOW ENTER CODE:09 & MACHINE WILL PRINT OUT ITS PRINT QUALITY CHECK SHEET.
(IGNORE INSTRUCTIONS PRINTED ON CHECK SHEET)
CHECK QUALITY & REPEAT BY USING CODE:84 IF NEEDED.
(YOU MAY HAVE TO DO THIS SEVERAL TIMES BUT YOU SHOULD SEE A STEADY IMPROVEMENT WITH EACH CLEANING CYCLE)
WHEN FINISHED AND QUALITY IS GOOD, ENTER CODE:99 TO RETURN TO STANDARD MODE.
PRESS MENU/SET 4, THEN MONO FAX START TO PRINT OUT
PRINT QUALITY CHECK SHEET & FOLLOW ON SCREEN INSTRUCTIONS.
Feb 11, 2008 | Office Equipment & Supplies
Mail merge tri fold printing
Whats the weight of the paper? Try a lighter weight paper. Also, did it do it when you first got it? If No, it is called a limitation, it can't be done. If it did have your service tech come out and clean or replace the feed rollers or clutchs.
Feb 04, 2008 | Panasonic DP-C264 Copier
Corrupt documents
please try to open the document on a diff machine and if it doesnt works then contact quark tech support for assistance
Jan 15, 2008 | Quark AVENUE XPRESS (115261) for Mac, PC
Acer Aspire One AOA110-1588 Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
