Question about Nokia N70 Cellular Phone
Problem with N81 slide
My nokia phone's display is turning off when opening slide or closing slide...
Hi, my N81 sometimes turns dim when i push some buttons and when i slide the screen. i dont know if its the flex because it turns to normal when i left the phone to standby or when i restart my phone.. pls...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Take care...
Mar 09, 2011 | Nokia N81
Tip
Unlock code of nokia
Ideal for Nokia Any BB5 Models including:
Nokia BB5 SL3 : N97, N97 mini, N900, 2220 Slide, 2700 classic, 2730 classic, 3600 slide V56.26, 3720 classic, 5130XM V59.42, 5230, 5310XM V58.58, 5630XM, 5730XM, 5800 navigation, 6202 classic, 6208 classic, 6260 slide, 6300 V57.20, 6303 classic, 6500 classic V59.45, 6500 slide V59.60, 6700 classic, 6710 navigator, 6720 classic, 6760 slide, 7230, 7310 supernova, E52, E55, N86 8MP, X3, X6
Nokia BB5+ SL2 RAP3 9DDB : 3600 slide, 5220 XpressMusic, 6600 Fold, 6600 Slide, 7210 Supernova, 7310 Supernova, 7610 Supernova, 7510a Supernova
Nokia BB5+ SL2 Rapido : 5800, 6110, 6120c, 6120N, 6121c, 6124c, 6210, 6220c, 6650, E51, E63, E66, E71, E75, N78, N81, N81, N79, N85, N82, N95_8GB, N96
Nokia BB5+ SL2 : 3120C, 3555, 3555b, 5310, 5310B, 5610, 5610D, 6263, 6300i, 6301, 6500S, 6500C, 6555, 7500, 7900, 8800 Arte
Nokia BB5 : 3109c, 3110c, 3250, 3500c, 3500cb, 5200, 5200b, 5300, 5300b, 5500, 6085, 6086, 6086b, 6125, 6126, 6133, 6131, 6136, 6151, 6233, 6234, 6280, 6300, 6300b, 6630, 6680, 6681, 6682, 7373, 7390, 8600, E50, E61, E61i, E62, E65, E90, N70, N71, N73, N75, N77, N80, N92, N90, N91, N91-8GB, N93, N95
on Apr 21, 2010 | Cell Phones
Unlock code for my nokia 6303
Apr 04, 2010 | Nokia 6303 Cell Phone
I have a n81 8gb mobile phone that showing only blue lcd
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jan 14, 2010 | Nokia N81 Smartphone
I changed the lcd cover of nokia n81.now when i turn on the mobile:the mobile is on but the display is black.pls help me out.thanks
You may have damaged the display or display connector. you can have a new display or connector repaired by www.fixphonenow.com cell phone repair service.
Jan 09, 2010 | Nokia N81
Dismantled and Put Together Again Nokia N81 not working.
Power related problem? Double check the battery terminal if exactly fitted to the board.
Oct 21, 2009 | Nokia N81
CAMERA PROBLEM
TRY THIS DEAR MAY BE DONE OTHER WISE ITS HARD WARE PROBLUME...............
1....
TURN OFF THE PHONE AND PUT OUT SIM AND MEM CARD
2....
NOW REINSERT BETARY AND PRESS POWER ON AND QUICKLY PUSH..,(SEND,,,*,,,,3)
TILL PHONE POWER ON PROPERLY AND DISPLAY COUNTRYS NAMES.
ITS FORMAT YOURS PHONE, YOU CAN ALSO FORMAT YOURS PHONE VID CODE THATS(*#7370#)THEN YOUR OWN PASSWORD.
QAISAR ALI SHAH
+923009555560
May 31, 2009 | Nokia N81 Smartphone
Nokia n96 back light
slide your phone open and the back light does not turn on. slide it closed and then wait until the front keypad light turns off and then slide open straight away. you will find that the back light then comes on. bit of a puzzler and a pain but has seemed to work so far.
Jan 08, 2009 | Nokia 5310 Cellular Phone
My nokia n81 automaticly quit applycations and menu...
click and hold menu button, you should see all the applications that are currently running, select them one by one and close all of them keeping the "phone" application only.
then click once to open the menu.
you can also turn off the phone then on again. but make sure to fully EXIT the application after you finish using it. this will keep your batter life longer and save phone memory on your phone, it will also preform much faster.
let me know if this helped :)
Jan 03, 2009 | Nokia N81
Loudspeaker Nokia N81 - 8 GB
do you have ab luetooth headset connected?
if so try closing the connection..
May 21, 2008 | Nokia N81 Smartphone
Nokia N70 Cellular Phone Logo
132 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
