Question about Danby DKC645BLS Compact Beverage Cooler
Inside fan on Keg Cooler needs to be replaced
The little fan inside my Danby DKC645BLS keg cooler started making a terrible noise and now has stopped running. Anyone know where I can get this part. I've googled the model number (which got me here) and can't find any parts supplier nor is the Danby web sit of any help unless I want to have someone come out to "service" it - which I don't. I just need the little fan
  • 4 Answers
Call them and ask to buy the part it should be pretty cheap. I just bought a replacement keypad for mine and they sold it to me right on the phone no hassles
Posted on Aug 07, 2009
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
No flow from keg
when was the beer hoe last cleaned? also have you checked the regulator on the tank......disconnect all hoses, and make sure all cloggs are cleared
Jan 01, 2009 | Danby DKC645BLS Compact Beverage Cooler
Foamy beer
Keg's are normally pressurized at 13 psi. If you only set yours at 8 psi then you are going to cause problems. You should always start at least the same psi that the keg is set to. If you can talk to the keg company as they all differ some. Common problem is to lower the psi which will cause foam until you reach about 1/2 full or a little less then you should get less foam but your beer will become very flat. Too much pressure is usually better than too little, even with too much pressure you'll see the beer come out fine but will start to foam when hitting the glass/pitcher. Also note that the coupler's that Danby use are very cheap, check the CO2 vale (between CO2 line and coupler) to see if there are any cracks or anything.
Sep 27, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby Keg cooler
Let me know if you need anything else, I'm replying so this message will come off my profile. Thanks, glad too help.
Jul 07, 2008 | Danby DKC645BLS Compact Beverage Cooler
Installing the lines to the keg
check to see weather or not a pump is needed to pressurize your keg.
Jan 26, 2008 | Danby DKC645BLS Compact Beverage Cooler
Major leaking with kegerator (DKC645BLS)
Using a tray is not the answer. Your tapper is not propperly lineing up with your kegs inlet. Try replacing your tappers washer and o ring, if this does not work you need to replace the tapper itself. It is most likely bent and not propperly lineing up.
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Compact Beverage Cooler Logo
348 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
