Back to:
Tags:
Jeep 10 x 20
1982 Jeep Cherokee no heat
posted by WillyJones on Nov 21, 2007
My son's 82 jeep full size cherokee heat control panel appears to be not functioning. When the heater is turned on you can hear the motor on but no forced air weather you select defrost, floor or panel. Wondering if it's simply the controller or something more involved?
Comment by WillyJones, posted on Nov 21, 2007
I tried it in all the positions but no luck. This has a separate under dash AC unit. Appreiciat the help with this. When he get's home will check the linkage and vacuum hoses.
I will and sure appreciate the help!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
trintek
Rank:Guru Guru
Rating: 88%, 183 votes
if you can hear the motor(fan) spinning, check the linkage that controls which vents are open, also check for a vacuum leak as the vacuum hoses on a jeep that old go out frequently and many times control the switching for the heater/defrost/ac. your first thing to do will be to grab a manual for this jeep and check the actual location of the heater/vent/ac fan. there is always the chance that the fan slipped off the motor (usually doesn't happen, but the circlips have been known to fail)
have you tried it in any other position? ie: vent or ac
Comment by trintek, posted on Nov 21, 2007
if you need any further help, please feel free to post a followup, i am a member or tx jeep corps and north american xj association, so have loads of resources when it comes to jeep issues, have loads of resources. when you check it, and if you can't figure out the problem, try to find a model or part number on it and i will see what i can find for you.
Rating Locked! (?) WillyJones has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 1982 Jeep Cherokee no heat:
I don't want to Accept this solution
Can you Help with these Binoculars problems?
Jeep 10 x 20
Just had transmission rebuilt two years ago and was...
Jeep 10 x 20
Hi, I have no a/c in my Jeep.. THere is a vent by the gas...
Jeep 10 x 20
how to replace right front pinion baring and seal
Jeep 10 x 20
i want to replace rear crown wheel and pinion on jeep...
Jeep 10 x 20
i am looking for the headlamp wiring harness for jeep...
Loading problems.
Repair Service
Find Binoculars Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
