I have a Model GLTF 2940 ESO Frigidaire front load washer that has been giving me an E 10 error code. None of the possibilitied listed on the Error Code chart seen to apply. I can fool it by using the Delicate or Heavy load programs - once, Then it does it again. I've been putting it on Rinse/Spin to finish off the load.
  • leeway_1 Jul 23, 2009
    How do I find the screens at the inlets? Thanks, Lee
    It's a great start to solving my problem! Thanks
  • 3,037 Answers
E10 is a water supply problem first I would check your water lines and check the water valves to see if both are open all the way. Next check to see if the screens at the inlets are clear, that all wires to the water valves in the machine are connected, and last if all else fails to be a problem, then you may need a new water valve in your washer. Let me know how this turns out.
Benjamin
Posted on Jul 23, 2009
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Error codes on a front load washer
Hello friend, thanks for your post!
From my understanding you would like a list of error codes that apply to your Frigidaire washer. Is there a specific error code you are searching for? I was unable to locate a list of all the codes that would be available within your washer, ATF7000E. With additional information I would be able to assist you further. -Matt
Feb 14, 2015 | Frigidaire Affinity ATF7000E Front Load...
I need a chart showing the error codes for a front load fridgedair washer model LTF2140ES3
Hi Richard....Google - Frigidaire front load washer error codes.
There are several links with code listings. Try the Sears Parts
Direct link.
Regards,
Dennis
Oct 10, 2014 | Cars & Trucks
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Oct 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
