Question about Cell Phones
Working very slow, freezing, internal error txting
Phone working very slow & showing internal error when trying to text. i have checked the memory & have plenty available. The phone was givin to me by a friend & he did not kno where the manual was & i cannot locate one online to try to research the problem myself
Discrepancy in Cell Phone Memory
Understanding RAM, SD Card and Device Memory of an ...
android.stackexchange.com/.../understanding-ram-sd-card-and-device-m...
Aug 19, 2014 - Device Memory is your phones built in memory, just like SD Card hasmemory ... as to the difference between SD memory and internal memory. .... Can I stop a fellow passenger from using their cell phone during take off?
Difference between "Device memory"... ' Samsung Galaxy S II I9100 ...
forum.xda-developers.com/.../difference-device-memory-usb-storage-t1...
Jul 13, 2012 - 5 posts - ‎4 authors
Difference between "Device memory" and "USB storage". ... Whats is the differencebetween device memory and USB storage? As far as i see all the apps installed on the Device memory and all the photos and other files are located on the USB storage.
Whats the Difference Between Flash Memory and SD ... - eBay
www.ebay.com > ... > Camera & Photo Accessories > Memory Cards
This guide will take a look at the differences between flash and SD memory, and ...from digital still cameras, video cameras/camcorders, tablets, to cell phones ...
android - Difference between INTERNAL SD CARD and ...
Jan 28, 2016 | Cell Phones
Sms restriction 45
TracFone International Texting Revoked
  • Certain mobileicon1.png phone upgrades affect the ability of TracFone customers to send text messages internationally. Some of the phones identified to have had this SMS issue are the LG290C, LG420G and Samsung T301G. The problem is present when an error message appears on your TracFone device after you send a text message to an international number that says, "Check SMS Restrictions."
Read more : http://www.ehow.com/info_8634048_trac-phone-problems.html Did you upgrade from the 420G to 440G? Certain mobile phone upgrades affect the ability of TracFone customers to send text messages internationally. Some of the phones identified to have had this SMS issue are the LG290C, LG420G and the Samsung T301G. The problem is present when an error message appears on your TracFone device after you send a text message to am international number that says, "Check SMS Restrictions"
Or your phone isn't capable of texting internationally.If it's supposed to then you need to call Tracfone customer service and tell them.
Mar 12, 2014 | Tracfone Wireless LG 440G
I've been having problems with my phone for a while now. It's been freezing up, cutting off by itself, & other random stuff. Today, I sent a text & the phone shut off! I did the usual 'take th
Try to check if your phone memory still have enough space. common cause for freezing and shutting off is when your phone memory is almost full. try deleting some stuff.
May 25, 2017 | Samsung M8800 Pixon - Unlocked QuadBand...
LG rumor 2 TEXTING LAGS
Go to a local dealer and you may need an update.
Sep 26, 2009 | LG RUMOR Cellular Phone
My phone keeps freezing and restarting
it will end up costing you about 15 dollars but take it to a repair shop for the provider you use and they should be able to save all your info and flash a new version of the software onto your phone but it won't be free, that's the only way to fix that without buying a new phone.
Dec 28, 2008 | Verizon Communications enV2 Cellular Phone
Cell phone freezes when i try to use my music from my memory card.
this happens sometimes. sometimes you just have to let it be frozen for a while, then it'll start working again
Oct 27, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Reception problems and slow
it is an internal memory problem try nokia care for help
Sep 02, 2008 | Nokia 5300 Grey Cellular Phone
Try pulling out your memory card if you have one. i had the same problem and come to find out my memory card must have come loose from dropping the phone. It's working fine ever since I took i out and put it back in. Good Luck.
Jun 23, 2008 | LG enV VX9900 Cellular Phone
Problem with sending a text message
hello alexann, Your phone is out of ram memory. Symbian phones use the internal memory as rom memory (dinamically allocated) ram memory (for user programs) and firmware storage. If the internal memory is almost full the phone will begin to give you such errors because it can't load into ram the text aplication that is require to start in order to process sms messages. Please try to avoid to fill the internal memory and instead move anything from it to the memory card. A full internal memory can result in slow phone operation, errors, program crashes or even the failure to boot-up (start) the phone. Therefore, in your case you should try to free more internal memory (phone memory) and check the sms folder to see if you can send messages. If this doesn't solve, you may have a virus or a bad program installation that corrupted symbian OS's registry. This will require to hard reset the phone. Please come back with a reply if these methods fail. Good luck!
Jun 06, 2007 | Nokia 3230
Cell Phones Logo
59 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
