Question about LG WM2277H Front Load Washer
LG WM2355C water leaking under machine after washing finished.
Water found under left front of machine next morning after washing done.
Small amount for small load, larger amount for large load.
Checked filter and all is clean and OK
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Posted on Sep 16, 2009
  • 6,784 Answers
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Posted on Jul 23, 2009
  • 3 Answers
I have a leaking WM2277HW and have the same solution as #3 (the rubber bellows underneath developed three small cracks that you can only see by spreading the rubber apart.) Simple to replace.
Posted on Oct 11, 2009
  • spovich Oct 11, 2009
    I meant to say same solution as #2 (not #3)
My Lg also has a little puddle left front of machine and dribbles on front of machine from detergent drawer which i think the water is coming from.
Posted on Jul 26, 2009
LEAKING SMALL AMOUNT OF WATER UNDER FRONT LEFT CORNER OF WASHER. LEAKS WHENEVER WATER GOES INTO THE DETERGENT DIPENSER.WHAT IS THE CAUSE?
Get a level and check the level of the machine. The front should be slightly higher than the back and even left to right.
Jun 02, 2015 | Maytag MVWB850YW Bravos XL HE Top Load...
LG WM2075CW seems to leak AFTER a load is finished. Wtare found front left under washer and also in the drawers of the pedestal. Anyones best guess?
(1) If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
(2) Check the tub seal for tears or cracks.
(3) Check the door boot seal for condition.
(4) Also check the tub-to-pump drain hose for cracks or tears.
(5) Lastly, check the drain hose for condition.
Replace whichever offending part that is found to be defective.
Mar 01, 2015 | LG Washing Machines
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
Jun 27, 2017 | LG WM2077CW Laundry XL Front Load...
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
We have a water leak coming from beneath our machine . Fault reports = 'OE'. what is the problem?
OE is really DE = Drain Error. This should have nothing to do with your water leak.
For the DE code, open the access panel on the lower left on front of the washer. Drain the last of the water out of the machine using the small hose found there, then unscrew the big knob next to the hose and remove. Clean out this filter. If nothing is in the filter, replace pump motor.
The most common source of a water leak is a small hole in the gray tub gasket at the door opening. Examine it very closely, looking for rubbed spots which may have developed a hole.
Feb 20, 2011 | LG Washing Machines
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag MAV7700, Grinding and water leak
open the front with a puttyknife there are 2 clips about 4" in on each side this wil open the top so you can remove the 2 screws holding the front panel on once removed you can see the guts of the unit..Let me know if you need more help
Jan 28, 2008 | Maytag MAV7600 Top Load Washer
LG WM2277H Front Load Washer Logo
1,697 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
