Question about Canon Cameras
Cannon Powershot A-620 black screen can't review
I own a cannon powershot A 620 camera. When I turn it on the screen is black. The shutter opens. I've changed the batteries. I can point the camera at an object and take a picture while the screen remains black. I put the card in a different camera and the A620 is taking pictures but you can't see anything on the screen.
  • Canon Master
  • 4,738 Answers
Did you accidentally press the DISP or DISPLAY button on the back of your camera? This manually turns the screen on and off to save batteries. You would then use the optical viewfinder to take pictures. To turn the screen back on, just press this button one more time.
Posted on Jul 24, 2009
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
I have A2200 cannon powershot camera but the flash is not working
You can Google your camera make/model and open the link to download your user manual in a PDF. I did this and picked the one below. Under the Table of Contents, pick Turning off the flash. The instructions to turn it on are there as well.
Hope this helps. Mike
CANON POWERSHOT A2200 USER MANUAL Pdf Download. www.manualslib.com > ... > Digital Camera > PowerShot A2200
View and Download Canon PowerShot A2200 user manual online. PowerShot A2200 Digital Camera. PowerShot A2200 Digital Camera pdf manual download.
Dec 16, 2012 | Cannon Cameras
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Hi, I have a Cannon Powershot A610 and when I take a picture the picture comes out too dark. How can I adjust the it? thanks
"Too dark" or do you really mean "totally black"? I'm asking because a stuck shutter is a very common failure mode for your particular model camera.
Apr 06, 2011 | Canon PowerShot A610 Digital Camera
The screan is black i can take picturs fine and record but i when i go take a pic the screen is black until i review the pic. Its not the shutters because the screen isnt black when i have it on video...
The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to cannon service centre. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
Thank you
Jun 10, 2010 | Canon PowerShot SD1000 Digital Camera
Cannon sd1000 lcd screen black. Can review pictures, but cannot take new pictures.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2010 | Canon PowerShot SD1000 Digital Camera
Screen is black on camera Cannon PowerShot SD750
Am assuming that you've already tried pressing the DISP button, and that didn't fix it. Have you tried downloading the photos since this occurred? Are they also black? If so, then you're likely experiencing a stuck shutter.
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
I'M PLANNING TO BUY A CANON SD950 DO YOU THING BY BUYING A MEMORY EXTREME 111 4 GB IS GOOD?.
I have owned several Cannon brand cameras (not this particular model) and have always been very happy with them. I would support the purchase of any Cannon product.
cnet gives this camera a good review.
http://reviews.cnet.com/digital-cameras/canon-powershot-sd950-is/4505-6501_7-32591168.html
May 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Cameras Logo
289 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
