Question about Haier hwr10xc6 Air Conditioner
Haier 5000 btu thru wall or window vents on top and both sides how far out the window should it be?
  • 867 Answers
Just a few inches, main thing is that its slightly tilted at the back to drain the condensated water outside
Posted on Jul 23, 2009
Does the Haier 5000 btu window unit drain water?
yes they do.. just be certain you keep the filter clean and the unit tilted to theout side about 1 inch or so.. Hope the helps let me know jon
Jul 31, 2011 | Haier hwr10xc6 Air Conditioner
I have a Haier Commercial Cool air conditioner, model CPRD12XC7, 12,000 BTU that has 2 hoses off the back and is made to be vented thru a window. I want to install it in a closet with no windows. Can I...
Mark, the two hoses serve different functions (Fresh Air Intake & Hot Air Exhaust). Therefore, they would have to remain separate. Also, Haier does not recommend extending the length of the hoses, to accommodate a specific change in installation. And yes, they can be vented through a wall to the outside. But, you would need to use something similar to a clothes dryer vent termination on the outside. Most exterior dryer vent terminations have insect screening and a flap door that opens when air from the dryer pushes it open. This would be fine for the exhaust hose, but not the Air Intake Hose. I guess if you could carefully remove the flap door. it could be used on the Air Intake hose. Also, keep in mind that the unit requires a minimum of one foot air space clearance off the back of the unit, for proper air circulation around the unit. If clothes will be hanging in this closet, that may present an air circulation issue.
Hope this helped you, please let me know. Thanks.
May 26, 2011 | Haier Heating & Cooling
Does kenmore 8000 btu air coditioner thru the wall require a separate sleeve for installation
No you can install that unit directly through the wall and trim around it...just make sure most of the side vents are exposed outside...
heatman101
Aug 21, 2010 | Kenmore 75085 Air Conditioner
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Mar 15, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
Window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
May 19, 2008 | Frigidaire FAC124 wall/Window Air...
Ac ices over
First you need to make sure the filter is clean to allow good air flow through the evaporator. If the filter is clean make sure the evaporator is not plugged up with dust and lint. If all that is ok your problem is the a/c BTU's is to big for the size room you have the a/c in and it is getting the room too cold. If that happens the evaporator will ice up and will not cool the room.
Jul 08, 2007 | Haier HWR06XC5 Wall/Window Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
328 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
