Question about Fisher and Paykel GWL11 Top Load Washer
Bowl spiner the bowl spiner has broken and i need to replace the whole bowl spiner
  • 28 Answers
If the machine you are complaining of is F&P smartdrive the bowl floats up off the splined shaft to agiatateand drops down to spin. With this fault check the bowl moves up and down shaft if it doesn't do so 1remove agiatator by undoing wing nut down inside agiatator and lifting out whole thing swrewed to the bottom of inner bowl you see greenish coloured cover holding the sline drive undo screws and lift off check and see if there is debris in the splines or 2 remove the scews holding the top deck down remove bib ring and check that nothing (eg sock washcloth or similar )has got stuck between inner and outer bowls.If fault code lights are coming up inform me what they are so I may be able to suggest other cause
Posted on Jun 21, 2008
What is a bowl spinner, my washer is only 3 years old and seems to not aggitate any more. The light come on complaining of either the water is too hot or the bowl is unbalanced. puting my clothes on the cold cycle and balancing the load does not do any good. the wash and spin cycle will run its cource and I get dirty clothes from it!@!#@#$$@@!!!*^!
Posted on Mar 14, 2008
Repair rear toilet flange leaking
Mark,
Assuming the bowl is not broken you will need to pull the toilet by removing the nuts on the bolts on either side of the bowl. Once the bowl is removed re,move the existing wax ring and discard it. Check the flange to see if it has been broken. If it has you may be able to use a spanner flange to repair it. If it not and the whole flange needs replacing I advise you contact a plumber as it may require a bit more knowledge and tools to correct the issue than you may have at your disposal. If all is well than you may only need to buy a new wax ring to replace the old one. I would buy two in case an issue occurs with one you will have a spare at your disposal. If the toilet rocked or tilted before you should grout the area beneath it before resetting the toilet. Once you reset the toilet and tightened the bolts all that is left is grouting the edge of the bowl where it meets the floor. I hope this assists you and thanks for using Fix Ya.
Feb 15, 2012 | Home
How to change a brake light on a 2002 Mazda Protege ?
When you open the boot, you will see the nut that is used to screw the brake light, use spiner to loose it then replace it.It is normally 8 spiner.
Sep 26, 2011 | 2002 Mazda Protege
My ps3 disc dose not spin and i dont know why becase i dont want to replace a part like the laser or spiner and only replace one part and need the other, is there a way to test what specific part is broken
We work everyday with ps3 bluray, the reason it wont spin is because your bluray lense is not detecting a DVD as for that it thinks there nothing so there no reason to move the spinner. i would recommend you to buy a a full deck with spinner and lens on ebay.
Thanks
www.1RepairStop.com
Aug 27, 2011 | Sony Playstation 3 (PS3) Console
The part which the paddle conects to in the bread bowl is broken / falling appart needs replacing where can i get the parts
Unfortunately parts are not usually available for bread pans. You have to replace the whole pan if you can find one.
Hank
Sep 08, 2009 | Kitchen Appliances - Others
Machine leaks during spin and is not the pump replaced it.
leackege is due to the dead of varshals in the rooter. u r spiner varshals(the rubber type substance between the body and the rooter spiner) must be replaced... if u just used it as it is u r motor wiring burns due to the laekege of water....
my idea helps u ....
Aug 23, 2009 | Washing Machines
I made the stupid mistake of leaving a small pair of nail scissors in my bathrobe before washing it in my WD860 Hotpoint. The scissors must have fallen between the rubber and steel drums as when it...
yes, just remouve the center part of the spiner, is a cap at the top, that is the spiner holder, onscrew it and lift it, then look under at the center.
Aug 12, 2009 | Washing Machines
WICH WIRES DO I HOOK UP TO RUN MOTOR USING 2 SPEED 7 WIRES RE BLU YEW BL PUR WH ORANGE
Have a appliance repairman come because, may cause electric fire or damage to you or property. the repairman should have wiring diagram.Some washers have a ele disgram on inside of machine panel. Hope this may help. Becareful with electric.
Jun 01, 2009 | Washing Machines
Need replacement mixing bowl-Toastmaster Bread maker model 1186
I had the same problem, called the phone number 800-947-3744 to see if I could get it fixed or replaced. They said that toastmaster doesn't make this model (or any breadmakers). therefore buying a replacement bowl is not an option. sorry....
Jan 23, 2009 | Toastmaster 1183N Bread Maker
Need replacement bowl
Depends where you are. These are the guys who sell the fans in the US (Through Amazon): Direct link; http://www.antonline.com/c_0_18317_5__3268_1_50.htm Company name: ANTonline Street address: 33 Mansell Court Suite 200 Roswell, GA 30076 USA Web site: http://www.antonline.com Customer-service phone, fax, and e-mail Phone: 877-293-9797 Fax: 770-874-0789 Email: support@antonline.com Hours: 9am-6pm Mon.-Fri. EST Also the fan is Known by the "Boston Harbor" name (same model number). If you are outside the USA, please ask again. Hope this helps :) ps the Amazon list price for the whole unit is $77, so check on replacement bowl prices before ordering - if the fan is more than a few years old, it may be better to replace completely.
Aug 22, 2007 | World Wide Sourcing (CFB5521F242WH)...
Fisher and Paykel GWL11 Top Load Washer Logo
135 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
