Paper stuck - crumpled viewed from the back; stuck in front but out of reach. Brother HL5170DN. Help!
    President:
  • 1,996 Answers
Here's a link to the online support page with detailed instructions for clearing paper jams from your machine. And this link will take you to the home support page for your model, in case you run into any further error messages or issues in the future.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
How can I remove a paper jam from under the fuser bar in Brother MFC-8440?
sometimes a good long pair of tweezers helps , I use fishing forceps myself . have 4 different sizes from 2 inch to 14 inch
Oct 27, 2015 | Brother MFC-8440 All-In-One Laser Printer
The paper won't feed through. it did one minute then stopped
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). This, if properly done should do it. Brush especially the rollers etc.
Dec 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
The paper stuck in the printer. What should I do? How can I get it from printer?
stuck where one is left to wonder...., one removes jams by open rear door or front and removing toner, or cassette, if it is crumpled in fuser, then it aint easy without pulling it apart, sometimes a manual feed via hand of a pice of stiff card or laminate in direction of paper path (dont pull it against direction nor should jams be pulled backwards), cut a point in lamiante to allow you to poke then pull threw removing paper fragments
Nov 07, 2009 | Brother HL-2040 Laser Printer
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
Sticker label stuck inside
Depends on where inside the machine the label got stuck. There's covers on the back, front (which also lets you remove the toner/drum unit for more access) and also the paper tray.
If you're unable to reach the label removing these parts/opening the covers, the machine would require to be screwed apart to reach it. There is no levels to release pressure on drum or similar to reach further within, unfortunately.
Jun 02, 2009 | Brother HL-2040 Laser Printer
Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Mar 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Red light stays on and will not print
there is a second piece of paper stuck in the machine.
open the back flap, look at the diagram, and pull out a piece of hardware
behind this hardware, all crumpled up, not visible, is a jammed piece of paper.
Jul 11, 2008 | Brother HL-5240 Laser Printer
My copier makes a noisy sound
Check the crumpled paper. If it has an image, it has reached the drum and is crumpling at the fuser unit (part that gets hot). If that is the case the fuser gear and drive gear need to be replaced.
May 01, 2007 | Sharp AL 1215 Black and White Copier
73 people viewed this question
jasbo
jasbo
