Question about Panasonic PV-20DF64 20 in. TV/DVD Combo
Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
My daughter put two discs into the dvd player at once. Now when I insert a dvd, it displays "reading," then displays "this type of disc cannot be played, please insert a different disc."
    Novelist:
  • 117 Answers
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Posted on Jul 23, 2009
Dvd player gives message "this
Tries many more DVD discs tries to check it out as the disc u insert in the DVD player tray have difference region format disc that why u getting that answer.
Jun 05, 2011 | Panasonic PV-DM2792 Triple Play 27 in....
I have a Sony DVD player (bought in 2004) and while it will play a new DVD once it will not play again. I've bought a DVD player cleaner, but it still won't play my DVDs (Error appears each time).
Tries wash all ur DVD Disc with dishing soap to clean out all the smushes,grims,oil from the finger prints,on the laser surface of the disc,it should play now.Not than u must take the tv aparts take some Q tips with some rubbing alcohol to clean the DVD laser eye it self.Long time DVD laser eye reader have contaminate from the air cause it not read discs.Especially house hold that smoke or live in dries heat states.
Apr 14, 2010 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Problem with the dve player
You may have to check the options for the player. Some DVD players cannot play formats other than regular DVDs. You can check the options to see if it can be put in a different mode from the normal one, such as progressive scan, which can help it to read DVDs better in some ways. You can also set it up to accept more types than just DVDs, but also DVD-Rs and VCDs. I cannot tell you, without fiddling around with it, whether you will need to take it in to a shop, but that is an option. Once you see about adjusting some of the settings, see if it won't play a DVD.
Oct 23, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Wont play dvd's.
If this happens when you insert a DVD disc then most likely the laser assembly is failing in the DVD drive. In most cases it will probably still play CD's. The part number needed is LSVQ0087 and isn't cheap as seen on the following ebay posting. Please take a moment to rate my answer. Thanks.
http://cgi.ebay.com/Panasonic-LSVQ0087-BLOCK_W0QQitemZ390013781267QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5acea20513
May 10, 2009 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
DVD PLAYER Locker
press the stop key on the television and the on/off button on the remote at the same time.
Dec 26, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Dvd player
it could be that your lens needs to be cleaned
Aug 07, 2007 | Panasonic PV-27DF64 27 in. TV/DVD Combo
Panasonic PV-20DF64 20 in. TV/DVD Combo Logo
186 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
