Question about Cameras
Lens is not moving after zooming out - Cameras
  • 3 more comments
  • peterfenley Jul 23, 2009
    Olympus 740 All weather.
    Also cannot take photos
    No change
    Camera sounds as if it is trying to close or at least go back to default but the lense does not move
  • peterfenley Jul 24, 2009
    Tried your suggestion but had no luck
    Thereis a whirring noise which sounds like the lens is trying to retract but nothing happens
    The camera is shutting down when the noise stops
    I haven't have a response to my last reply so can somebody else assist??
  • peterfenley Jul 25, 2009
    I have done evverything you have suggested with no luck.
    Any more ideas???
    President:
  • 1,197 Answers
A low battery
will do this, so make sure that is not the problem by changing the new batteries....
sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
if ur still unable to retract the lens....... ur lens motor assembly is broken and wud need replacement..... contact olympus as u have no other options left.....
Posted on Jul 24, 2009
  • SAM JAYANTH CHANDRASEKAR
    like i said those are the only options at ur disposal ... if after doing all of the above ur not able to retract the lens... the lens motor assembly is faulty and wud require to be replaced.....
    contact olympus....
    good luck and have a nice day
  • 453 Answers
Can I know the model and the make of the camera?
Posted on Jul 23, 2009
  • Sai Kiran Camsarapalli Jul 23, 2009
    Kindly comment.
    Try to reset the camera by going in to the settings.
    Once this is done. Remove the battery, Remove the memory card. Put the battery on without the memory card and turn on. Try this and kindly comment.
How do I zoom in and out on a photo?
This camera has a 9mm lens, and while shooting, you can't zoom. For that you need a zoom lens. You can buy one from Samsung.
I checked the manual, and it also does not show how to zoom in on a picture when it is on the display. So I guess, you should view it on a computer, or tablet ant use the picture viewer on that device to zoom in.
Be aware you have a great camera and the result with a prime (one focal length) is superior to the results make with a zoom lens.
But if you don't like to move around, to farm the picture, a zoom lens can be convenient.
Oct 07, 2014 | Samsung Nx Mini Smart Camera With 9mm Lens...
I have a new Nikon 3100. The problem now is my 18-55 zoom lens is locked and it won't move. In the manual setting and by unclicking the outer lens auto button, the focus front lens is fine. It'
Simple answer; NO! What ever you do; do not try to force anything to move and don't try to disassemble the lens. Contact a Nikon Repair Depot (found in your instruction manual or on the Nikon USA website) and they will give you instructions for returning it for a repair estimate. If it is still in warranty, there should be no charge.
Dec 31, 2012 | Nikon D3000 D3100 18-55mm
How to zoom in using Canon EOS Rebel XS?
Zooming is done from the lens on a DSLR, assuming you have a zoom lens on the camera. For example, if your camera came with the 18-55mm lens, you should see the numbers 18, 24, 35 and 55 on the lens barrel with a white index line next to one of the numbers. Turn the barrel to move a different number next to the index line. 18mm is wide angle, 55mm is 'zoomed in'.
Mar 12, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
.bnklghl;
The lens can move in and out in straight line. If, due to the hit the lens casing got bent then it will stop moving. The glass may be fine but the casing seems to have taken a dent and is touching the sides somewhere. And to zoom in or out the lens have to move in and out. Try to get the lens in the middle of the lens well. Try to pull it out when powering on.
Nov 30, 2009 | Casio Exilim EX-Z750 Digital Camera
My Casio Exilim 7.2 Megapixel camera is stuck on zoom.
ur zoom lens trrip is broken 1side dont use zoom inout strip cost 50$
Jun 18, 2009 | Casio EXILIM Digital Camera
Distance scale does not move on canon efs 17-85mm lens
Yes, this is normal. Some zoom-lenses adjust the focus when zooming, to always keep the subject in focus. Those tends to be the more expensive lenses.
So you don't have to worry, nothing is wrong with your lens.
/Chris
Jan 10, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Friction in zoom, Sigma AF 70-300mm for Canon-EOS
Its more like a distorted inner zoom barrel or sand and dirt inside  the inner barrel will need to be replaced or you need to dismantle and clean out
Nov 09, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Pentax espio 140
subaru662,
can you see the lens in the finder move when you zoom out? if not ,the finder lens is stuck.
if it does move when zooming, see if you have a diopter adjustment wheel or sliding knob near the front lens of the finder. if so adjust the lens to your eye.
Jun 28, 2008 | Pentax Espio 140V 35mm Point and Shoot...
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
Zoom lens
What camera are you using is the lens making a noise when it stops focusing  call sigma imaging uk 01707 329999
Oct 19, 2007 | Sigma AF 28-200 Lens
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
