SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor Check fan motor for continity IF none replace fan motor
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
