Question about Microwave Ovens
Hi I'm thinking of getting an OTR mictowave and was wondering if I have to install an outlet in the cabinets or can I just place it where the existing wires for the hood fan are. This location would be directly behind the microwave and I'm concerned then it won't fir properly against the wall. Thanks for the help
  • 672 Answers
The outlet needs to be in the cabinet above. The microwave needs a dedicated circuit. Turn the power off to the hood and see if any lights or outlets go off on the same curcuit. If only the hood is on that line your good to go with that wire if it meets requirments. Our code asks for 15 amp breaker and 12/2 grounded wire. If it meets your local requirments, just take it up inside the wall to your new outlet location(usually there is enough wire to reach) and install a box, outlet and cover.
Posted on Jul 24, 2009
I removed the bolts for my Danby OTR microwave. Dmw162w-otr. The microwave does not move. Are there any other bolts or is there anything I am missing before I can remove the microwave?
In a normal installation, there is a plate that mounts to the wall and bolts come down through the cabinet. Once the bolts are removed from the cabinet above mic, the mic should hindge forward. It takes two people to handle. How ever, in some cases an installation guy will add screws into the side of the unit. So look for some screws to the right and left of mic. Good luck!
Jan 29, 2016 | Danby Microwave Ovens
How do I get the "surround" panel off ? My JE2160 keeps shorting out when the door latch release is pushed.... wondering if it is a circuit in my garage..... or something wrong with microwave. Would...
You have a serioius problem which requires professional intervention. Your oven should Never 'arc' between the door and the cabinet. Evidently, the oven is charging the door (which should not happen) and the charge is not properly leaking to a proper ground.
Thanks for your interest in FixYa.com
Oct 03, 2010 | GE Microwave Ovens
Can I replace a 1.3 cu ft otr microwave with a 1.5
Brackets can remain the same throughout a particular brand for several years but will also change every year at times. Same year and same brand, I would say yes. Different year of manufacture or different brand name I would say, no it will not fit the existing brackets. If you have a particular brand in mind and have the model number of the existing OTR, it is usually possible to search out installation instructions for both at the manufacturer's website. You could then compare to see if they will match up. The two screws through the upper cabinet floor into thr top of the OTR can vary, within a particular brand even in the same year of manufacturer.
Mar 14, 2010 | Microwave Ovens
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Peninsula otr microwave installation
I cannot comment on this. On something that is non-standard and specifically warned against in the manual, I would only comment if I were there to inspect it.
I would get a pro's on-site opionion.
Jul 30, 2008 | Microwave Ovens
How to Remove an OTR Microwave from the wall
first you need to take the grill off the front of the micro there should be two screws on the very top of the unit that allow you to take the grill cover off there also should be two screws in the cabinet above the micro that hold the unit in place some models have a silver hook or latch on the left side that you pull forward to release the unit from the back plate do not pull on this till you have taken out the two set screw on top of the cabinet after doing this the micro should come down
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Otr microwave install
We have a partial service manual for that model on our site at http://www.microwavedisplay.com/MV1615x_Service_Manual.pdf
It shows an exploded view of the installation on page 8-7 but for some reason the parts list (with part numbers) is missing.
But this page *should" answer your question.
If yours is not a Goldstar MV-1615, please reply back with your brand and model.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 11, 2008 | Goldstar MV-1615 Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
