Kia Master
- Posted on Mar 19, 2017
Re: How to change thermostat on a 2005 kia sedona
- Drain the coolant
The thermostat is located at the end of the top radiator hose. Remove the drain plug from the radiator and flush the coolant into a pan.
- Remove the Upper radiator hose
Loosen the clamps that connect the upper radiator hose to the housing and remove the hose.
- Remove the thermostat housing
Loosen the thermostat housing mounting bolts. Remove the housing and pull the thermostat from it.
- Replace the thermostat
Inspect the new thermostat and install it with a new gasket. Mount the housing and upper radiator hose. Then pour new coolant into the radiator.
